Samsung ProXpress MFP SL-M4560, SL-M4562 - Redistributing Toner
When the toner cartridge is near the end of its life:
  • White streaks or light printing occurs and/or density varies from side to side.
  • The Status LED blinks orange. The toner-related message saying that the toner is low might appear on the display.
  • The computer’s Samsung Printing Status program window appears on the computer telling users which toner cartridge is low on toner, see Using Samsung Printer Status.
If this happens, users can temporarily improve print quality by redistributing the remaining toner in the cartridge. In some cases, white streaks or light printing will still occur even after users have redistributed the toner.
Illustrations on this user guide might differ from the printer depending on its options or models. Check the printer type, see Printer overview.
If toner gets on the user's clothing, wipe it off with a dry cloth and wash clothing in cold water. Hot water sets toner into fabric.
The following instructions shows how redistribute the toner for the SL-M4560, SL-M4562 series printers:
  1. Open the front door.
    Figure : Example of opening the front door
  2. Unlock the toner cartridge.
    Figure : Example of unlocking the toner cartridge
  3. Pull on toner cartridge handle, and then remove from the printer.
    Figure : Example of pulling on toner, and then removing
  4. To redistribute the toner, gently rock the toner cartridge from side to side.
    Figure : Example of gently rocking the toner cartridge
  5. Install the toner cartridge back into the printer.
    Figure : Example of installing the toner cartridge
  6. Lock the toner cartridge back inside the printer.
    Figure : Example of locking the toner cartridge in place
  7. Close the front door.
    Figure : Example of closing the front door
