Samsung ProXpress MFP SL-M4560, SL-M4562, SL-C4060, SL-C4062 - Basic Copying
Basic copy
This document provides steps for basic copying original documents.
  1. Tap Copy from the home screen or Apps.
  2. Place the originals face up in the Dual Scan Document Feeder (DSDF) or place a single original face down on the scanner glass and close the Dual Scan Document Feeder (DSDF). See Loading Originals.
  3. Adjust the settings on the Copy tab and More tab.
  4. Enter the number of copies desired on the numeric keypad (or +, - button) on the control panel, if necessary.
  5. Tap , Start button from the control panel to begin copying.
To cancel the copying job during the operation, press the Stop/Clear button and the copying will stop. Tap Job Status on the control panel. Then delete the job you desire.
