Samsung ProXpress Color SL-C4010, SL-C4012 - Setting the Toner Low Alert
If the amount of toner in the cartridge is low, a message informing the user to change the toner cartridge appears. Users can set the option for whether this message appears.
Accessing menus might differ from model to model, see Accessing the menu.
  1. Select (Menu) > System Setup > Maintenance > TonerLow Alert on the control panel.
  2. Select the appropriate option, then press OK.
  3. Press (Cancel) to return to ready mode.
