HP ENVY x360 - 15-bp152nr Product Specifications
1KS77UA
Intel® Core™ i7-8550U (1.8 GHz base frequency, up to 4 GHz with Intel® Turbo Boost Technology, 8 MB cache, 4 cores)
16 GB DDR4-2400 SDRAM (1 x 16 GB)
Video graphics
  • Intel® UHD Graphics 620 (up to 8.06 GB)
  • Integrated
  • 1 TB 7200 rpm SATA
  • 128 GB PCIe® NVMe™ M.2 SSD
  • [15]
  • [14]
15.6" diagonal FHD IPS micro-edge WLED-backlit multitouch-enabled edge-to-edge glass (1920 x 1080)
Keyboard
Intel® 802.11b/g/n/ac (2x2) Wi-Fi® and Bluetooth® 4.2 Combo
1 USB 3.1 Type-C™ Gen 1 (Data Transfer up to 5 Gb/s, DP1.2, HP Sleep and Charge); 2 USB 3.1 Gen 1 (1 HP Sleep and Charge); 1 HDMI; 1 headphone/microphone combo
35.97 x 24.88 x 1.96 cm
2.15 kg
65 W AC power adapter
3-cell, 55.8 Wh Li-ion
Bang & Olufsen, dual speakers
HP CoolSense; HP ePrint; HP Audio Switch; HP Jumpstart; HP Recovery Manager; HP Support Assistant; HP Sure Connect
Pre-installed software
Netflix
