Samsung MFP SL-K3250-K3300, MultiXpress Color MFP SL-X3220-X3280 - Replacing the Waste Toner Container
This document explains how to replace the waste toner container. The status LED turns orange, and a message appears on the control panel screen display, indicating the waste toner container needs to be replaced. Check the waste toner container for your machine.
Replacing the waste toner container
Select the appropriate printer model for steps to replace the waste toner container.
