Samsung ProXpress SL-M3820, SL-M4020 - Replacing the Toner Cartridge
This document explains how to replace the toner cartridge. When a toner cartridge has reached the end of life, the machine will stop printing. A toner cartridge has almost reached its estimated cartridge life when:
  • The status LED and the toner-related message on the display indicate when the toner cartridge should be replaced.
  • The computer’s Samsung Printing Status Program window appears on the computer telling you when the cartridge is empty.
  • Shake the toner cartridge thoroughly, as it will increase the initial print quality.
  • Illustrations may differ from your printer depending on its options or models. Check your printer type.
  • To prevent damage to the toner cartridge, do not expose it to light for more than a few minutes. Cover it with a piece of paper, if necessary.
  • Do not touch the green area of the toner cartridge. Use the handle on the cartridge to avoid touching this area.
  • Do not use sharp objects such as a knife or scissors to open the toner cartridge package. They might scratch the drum of the cartridge.
  • If toner gets on your clothing, wipe it off with a dry cloth and wash clothing in cold water. Hot water sets toner into fabric.
Replacing the toner cartridge
Use these steps to replace the toner cartridge.
  1. Open the front cover.
    Figure : Open the front cover
  2. Remove the used toner cartridge from the printer.
    Figure : Remove the used toner cartridge
  3. Depending on your printer model, use these steps:
    • For M3320 M3820 M4020 series:
      1. Remove the new toner cartridge from the packaging.
        Figure : Unpackage the new toner cartridge
      2. Remove the cover from the new toner cartridge.
        Figure : Remove the cover
      3. Remove the sealing tape from the new toner cartridge.
        Figure : Remove the sealing tape
      4. Gently rock the toner cartridge back and forth to distribute the toner.
        Figure : Gently rock the toner cartridge
    • For M3325 M3825 M4025 series:
      2. Remove the protective shield and sealing tape from the new toner cartridge.
        Figure : Remove the protective shield
      3. Gently rock the toner cartridge.
  4. Gently insert the new toner cartridge into the printer until it snaps in place.
    Figure : Insert the new toner cartridge
  5. Close the front cover.
    Figure : Close the front cover
