Samsung MFP SL-K3250-K3300, MultiXpress Color MFP SL-X3220-X3280 - ID Card Copying
ID copy
The printer prints one side of the original on the upper half of the paper and the other side on the lower half without reducing the size of the original. This feature is helpful for copying a small-sized item, such as a business card.
  • This copy feature is available only when placing originals on the scanner glass.
  • The size of the 2-sided originals must be smaller than A5, if not, some of it will not be copied.
  1. Touch Copy from the display screen.
    Figure : Display screen
  2. Touch the Advanced tab > ID Copy from the display screen.
  3. Select a tray in Paper Source.
  4. Follow the steps on the display screen.
  5. Place the front side of an original facing down on the scanner glass as shown below, and close the RADF.
    When placing an original on the scanner glass, leave a little space between the edge of the scanner glass and the original. Otherwise, part of original might not be printed.
    Figure : Scan front side
  6. Press (Start) on the control panel. The printer starts scanning.
  7. Turn the original over and place it on the scanner glass as shown below, and then close the RADF.
    Figure : Scan back side
  8. Press (Start) on the control panel to begin copying.
    Figure : Scanned copy
    • If the original is larger than the printable area, some portions might not be printed.
    • If users do not press the (Start) button, only the front side will be copied.
    • If users press the (Stop) button, the printer cancels the copy job and returns to ready mode.
Manual ID copy
The Manual ID Copy menu allows users to customize the ID Copy layout to print up to four originals on a single sheet. Users can use this menu to define the scanning position of the originals and the layout of the printed sheet.
Setting up manual ID copy
The Manual ID Copy Setup menu allows users to customize the manual ID copy template.
Creating a new template
  1. Touch Printer Setup from the display screen.
  2. Touch Application Settings > Copy Settings from the display screen.
  3. Select a Manual ID Copy Setup > New.
  4. Select the Template Name, then type the name of the template.
  5. Select the Scan Position, then input the location of the original on the scanner glass (mm).
    Figure : Scan position
    • Users can define the scan area using two sets of x and y coordinates.
    • (Left, Top): Input the x and y coordinates for the top left corner of the ID.
    • (Right, Bottom): Input the x and y coordinates for the bottom right corner of the ID.
    • The Scan Position is defined by the rectangle created between the Left (0 - 272 mm, 0 - 10.72 inches), Top (0 - 407 mm, 0 - 16.04 inches) and Right (25 - 432 mm, 0.98 - 17.02 inches), Bottom (25 - 297 mm, 0.98 - 11.7 inches) coordinates.
  6. Select the Number of images, then select the number of images to include on the output sheet. The maximum number of image is four.
  7. Select the Image Position, then input the coordinates for the Image Position (mm).
    Figure : Image position
    • Users can specify where to print the scanned images using two sets of x and y coordinates.
    • The Image Position is defined by the rectangle created between the Left (0 - 331 mm, 0 - 13.04 inches), Top (0 ~ 191 mm, 0 - 7.52 inches) and Right (25 - 216 mm, 0.98 - 8.5 inches), Bottom (25 - 356 mm, 0.98 - 14.02 inches) coordinates.
Editing a template
Select this setting for edit of manual ID copy template.
Deleting a template
Select this setting for delete of manual ID copy template.
  3. Select Manual ID Copy Setup.
  4. Select a template and touch Delete.
Using the manual ID copy
  3. Touch Manual ID copy, then select the desired option.
    • Template: Allows users to select an existing template, see Setting up manual ID copy.
    • Print now: Prints only one side of the ID.
    • ID Copy: Specifies the default ID Copy method, see ID copy.
  6. Press (Start) on the control panel, the printer starts scanning.
