Product Specifications for the HP ENVY Photo 6220 All-in-One Printer (K7G20D)
Product naming
Model name
K7G20D
What's included and accessories
What's in the box
HP ENVY Photo 6220 All-In-One; HP HP 804 Black Ink Cartridge (~200 pages); HP HP 804 Tri-color Ink Cartridge (~165 pages); Ink Caution Flyer; Power Cord; Setup card; Getting started guide
Connectivity
Ports
1 USB 2.0 client; 1 Wi-Fi 802.11 b/g/n, dual band Wi-Fi 2.4/5 Ghz; BLE
Wireless capability
Yes, built-in dual band Wi-Fi 802.11 b/g/n
Copy
Color copy capability
Yes
Maximum number of copies
Up to 50 copies
Copy speed, black (draft, A4)
Up to 21 cpm
Copy resolution
600 x 600 dpi
Environmental
Acoustic power emissions
6.1 B(A) (print monochrome, simplex, normal mode at 8ppm)
Acoustic pressure emissions
53 dB(A) (print monochrome, simplex, normal mode A4 at 8ppm)
Operating humidity range
20 to 80% RH
Non-Operating humidity range
10 to 90% RH (non condensing)
Recommended operating temperature range (Celsius)
15 to 32ºC
Recommended operating temperature range (Fahrenheit)
41 to 95ºF
Storage temperature range (Celsius)
-40 to 60ºC
Storage temperature range (Fahrenheit)
-40 to 140ºF
Memory
Memory
256 MB DDR3
Memory card compatibility
No
Mobile printing capability
Mobile printing services
HP ePrint; Apple AirPrint; Mopria-certified; Wireless Direct Printing
Networking
Network protocols, supported
IPv4, IPv6, Bonjour, Custom Raw Port/Port9100, mDNS, Embedded Web Server, Wireless Network Supported,SLP, WS-Print, Wireless b/g/n, WEP/WPA (AES), SNMP, Internet Printing Protocol, Bluetooth LE
Paper handling
Input capacity
Up to 125 sheets
Standard input capacity (cards)
Up to 40 cards
Standard input capacity (envelopes)
Up to 5
Standard input capacity (transparencies)
Up to 40 sheets
Standard input capacity (secondary tray)
Up to 15 sheets
Output capacity
Up to 25 sheets
Media sizes supported (metric)
A4; A5; B5; DL; C6; A6
Media sizes supported (U.S. standard)
Letter, Legal, 4 x 5 in, 4 x 6 in, 5 x 7 in, 8 x 10 in, No. 10 envelopes
Media sizes, custom (metric)
97.79 x 215 to 127 x 355 mm
Media sizes, custom (U.S. standard)
3.85 x 8.5 to 5 x 14 in
Media types
Plain Paper; HP Photo Papers; HP Matte Brochure or Professional Paper; HP Matte Presentation Paper; HP Glossy Brochure or Professional Paper; Other Photo Inkjet Papers; Other Matte Inkjet Papers; Other Glossy Inkjet Papers, Plain Paper, Light/Recycled
Media weight supported (metric)
Tray 1: A4: 75 to 90 g/m²; HP envelopes: 75 to 90 g/m²; HP Photo Paper: up to 250 g/m²; HP 10 x 15 cm photo paper: up to 250 g/m²
Media weight supported (U.S. standard)
19 to 23 lb
Borderless printing
Yes (up to 8.5 x 11 in, 216 x 297 mm)
Paper handling - ADF
Automatic document feeder capacity
No ADF
Physical dimensions
Maximum dimensions (W x D x H, metric)
453.5 x 503.5 x 159.2 mm
Maximum dimensions (W x D x H, U.S. standard)
6.34 x 17.87 x 16.14 in
Weight (metric)
6.70 kg
Weight (U.S. standard)
14.74 lb
Power
Energy savings feature technology
HP Auto-Off Technology
Built-in Universal Power Supply
Power supply
Input voltage: 100 to 240 VAC (+/- 10%), 50/60 Hz (+/- 3 Hz)
Power consumption
13.95 watts (printing), 3.60 watts (ready), 0.93 watts (sleep), 0.20 watts (off)
Print cartridges
Number of print cartridges
2:1 black, 1 Tri-color (cyan, magenta, yellow)
Replacement cartridges
HP 804 Black Ink Cartridge (~200 pages); HP 804 Tri-color Ink Cartridge (~165 pages); HP 804XL Black Ink Cartridge (~600 pages); HP 804XL Tri-color Ink Cartridge (~415 pages). Average based on ISO/IEC 24711 or HP testing methodology and continuous printing. Actual yield varies considerably based on content of printed pages and other factors. For details see http://www.hp.com/go/learnaboutsupplies
SureSupply note
HP SureSupply alerts you when you should replace a print cartridge and helps you purchase locally or via the Internet. For more information, visit http://www.hp.com/learn/suresupply. Only available with original HP supplies; Internet access required.
Printing specifications
Print technology
HP Thermal Inkjet
Duplex printing
Automatic
Print speed black (ISO)
Up to 13 ppm
Print speed color (ISO)
Up to 8 ppm
Print resolution (best)
Up to 1200 x 1200 rendered dpi (when printing from a computer)
Maximum print area (metric)
209.9 x 349.6 mm
Maximum print area (U.S. standard)
8.26 x 13.76 in
Monthly duty cycle
Up to 1000 pages
Regulatory specifications
Regulatory model number
SNPRC-1701-03
Scan
Scan technology
CIS
Scan resolution, hardware
Up to 1200 dpi
Levels of grayscale
256
Scanning options (ADF)
No ADF
Maximum flatbed scan size (metric)
216 x 297 mm
8.5 x 11.69 in
Twain version
Version 2.1
System requirements
Minimum system requirements for Windows
Windows 10, 8, 7: 1 GHz 32-bit (x86) or 64-bit (x64) processor, 2 GB available hard disk space, CD-ROM/DVD drive or Internet connection, USB port, Microsoft Internet Explorer. Windows Vista (32-bit only): 800 MHz 32-bit (x86) processor, 2 GB available hard disk space, CD-ROM/DVD drive or Internet connection, USB port, Microsoft Internet Explorer 8. Windows XP SP3 or higher (32-bit only): any Intel Pentium II, Celeron or 233 MHz compatible processor, 850 MB available hard disk space, CD-ROM/DVD drive or Internet connection, USB port, Internet Explorer 8.
Recommended system requirements for Windows
Minimum system requirements for Macintosh
Mac OS X v10.12 (Sierra), v10.11 (EI Capitan), v10.10 (Yosemite); 1 GB hard drive; Internet access
Recommended Macintosh system requirements
Mac OS X v10.12 (Sierra), v10.11 (El Capitan), v10.10 (Yosemite); 1 GB hard drive; Internet access
Compatible network operating systems
Windows 10, 8, 7, Vista, XP SP3 or higher (32-bit only), Win Server 2008 R2 and higher (via the command line installer), Mac OS X v10.12 (Sierra), v10.11 (El Capitan), v10.10 (Yosemite)
One-year limited hardware warranty
