Samsung MFP SL-K3250-K3300, MultiXpress Color MFP SL-X3220-X3280, MultiXpress MFP SL-K4250-K4350, Color MFP SL-X4220-X4300 - Opening Printer Preferences
This document shows you the available printing preferences and the various options within each preference. Some of these printer preferences include setting favorites, layout options, paper options, color mode, staple options, watermarks, and eco printing.
When you select an option in Printing Preferences, you may see a warning mark, , or . An exclamation mark means you can select the specific option but it is not recommended, and mark means you cannot select that option with the current settings or environment.
