Samsung MFP Printers - Fax Features
  • The fax function is not supported for the following model printers:
    • C48xFN/C48xFW series, only.
    • M207x series
    • M267xN/M287xND/M287xDW
    • SCX-465x/465xN/4021S/4321NS/4621NS series
  • For basic faxing features, refer to "Basic Faxing" in your printer's User Guide.
Automatic redialing
When the number you have dialed is busy, or there is no answer when you send a fax, your device automatically redials the number. The redial time depends on the country's factory default setting.
When the display shows Retry Redial?, press (Start) button to redial the number without waiting. To cancel the automatic redialing, press (Stop/Clear).
To change the time interval between redials and the number of redial attempts do the following steps.
1
Press (Fax) > (Menu) > Fax Setup > Sending on the control panel.
2
Select Redial Times, or the Redial Term, you want.
3
Select the option you want.
Redialing the fax number
1
Press (Redial/Pause) button on the control panel.
2
Select the fax number you want.
Ten recently sent fax numbers, with ten received Caller IDs, are shown.
3
When the original is loaded in the document feeder, your device automatically begins to send the fax.
If an original is placed on the scanner glass, select Yes to add another page. Load another original and press OK. When you have finished, select No when Another Page? appears.
Confirming a transmission
When the last page of your original has been sent successfully, your device returns to ready mode.
When something goes wrong, while sending your fax, an error message appears on the display. If you receive an error message, press (Stop/Clear or Cancel) to clear the message and try to send the fax again.
You can set your fax device to print a confirmation report automatically each time sending a fax is completed. Depending on your printer/fax device, do one of the following:
  • Press (Fax) > (Menu) > Fax Setup > Sending > Fax Confirm on the control panel.
  • Press (Fax) > (Menu) > Fax Setup > Sending > Send Report on the control panel.
  • Press (Fax) > (Menu) > System Setup > Report > Fax Confirm on the control panel.
Sending a fax from your computer
This feature may not be available depending on the model, or optional goods, of your setup (see "Features by model" in your printer's User Guide).
You can send a fax from your computer without going to your fax device.
Make sure that your fax device and the computer are connected to the same network.
Sending a fax (Windows)
To send a fax from your computer, the Samsung Network PC Fax program must be installed. This program is installed when you install the printer driver.
For more information about Samsung Network PC Fax, click Help ().
1
Open the document to be sent.
2
Select Print from the File menu.
The Print window will be displayed. It may look slightly different depending on your application.
3
Select Samsung Network PC Fax from the Print window.
4
Click Print, or OK.
5
Enter the recipient's fax number and set the options, if necessary.
6
Click Send.
Checking the Sent Fax list (Windows)
You can check the Sent Fax list from your computer.
From the Start menu, click Programs or All Programs > Samsung Printers > Network PC Fax > Fax Transmission History. Then, the Fax Journal window appears with the list of faxes sent.
For more information about Fax Transmission History, click Help ().
Delaying a fax transmission
You can set your fax device to send a fax at a later time when you will not be present. You cannot send a color fax using this feature.
1
Place a single document face down on the document glass, or load the documents face up into the document feeder (see "Loading originals" in your printer's User Guide).
2
Select (Fax) on the control panel.
3
Adjust the resolution and darkness to suit your fax needs (see "Adjusting the document settings" presented later in this document).
4
Press (Menu) > Fax Feature > Delay Send on the control panel.
Or select Fax > Delayed Send > To.
5
Enter the number of the receiving fax machine and press OK.
6
The display asks you to enter another fax number to send the document.
7
To enter more fax numbers, press OK when Yes highlights, ard repeat step 5.
  • You can add up to 10 destinations.
  • Once you have entered a group dial number, you cannot enter another group dial number.
8
Enter the job name and the time when you want the fax to send.
If you set a time earlier than the current time, the fax will be sent at that time on the following day.
9
The original is scanned into memory before transmission.
The machine returns to ready mode. The display reminds you that you are in ready mode and that a delayed fax is set.
You can check the list of delayed fax jobs:
Press (Menu) > System Setup > Report > Scheduled Jobs on the control panel.
Adding documents to a reserved fax
1
2
Press (Fax) > (Menu) > Fax Feature > Add Page on the control panel.
3
Select the fax job and press OK.
When you have finished, select No when Another Page? appears. Your fax device scans the original into memory.
4
Press (Stop/Clear or Cancel) to return to ready mode.
Canceling a reserved fax job
1
Press (Fax) > (Menu) > Fax Feature > Cancel Job on the control panel.
2
Select the fax job you want, and then press OK.
3
Press OK when Yes highlights.
The selected fax is deleted from memory.
4
Press (Stop/Clear) to return to ready mode.
Sending a priority fax
This function is used when a high priority fax needs to be sent ahead of reserved operations. The original is scanned into memory and immediately transmitted when the current operation is finished.
1
2
Press (Fax) > (Menu) > Fax Feature > Priority Send on the control panel.
Or select Fax > Priority Send > To.
3
Enter the destination fax number and press OK.
4
Enter the job name and press OK.
5
Your fax device begins to scan and send a fax to the destination.
Forwarding a sent fax to another destination
You can set your fax device to forward a sent fax to other destinations by a fax, an email, or a server. If you are out of office, but have to receive the fax, this feature may be useful.
  • Although you may have sent or received a color fax, the data is forwarded in grayscale.
  • Forward options may not be available depending on your printer/fax device model, or optional goods installed (see "Variety feature" in your printer's User Guide).
  • When you forward a fax by an email, you must first set the mail server and IP address in SyncThru Web Service (see "Using SyncThru Web Service" in your printer's User Guide).
1
2
Use one of the following options to forward a sent fax to another destination:
  • Press (Fax) > (Menu) > Fax Feature > Send Forward > Forward to Fax > On on the control panel.
  • Press (Fax) > (Menu) > Fax Feature > Send Forward > Fwd. to Email > On on the control panel.
  • Press (Fax) > (Menu) > Fax Feature > Forward > Fax > Send Forward > On on the control panel.
3
Enter the destination fax number, email address, or server address and press OK.
4
Subsequent sent faxes will be forwarded to the specified fax machine.
Forwarding a received fax
You can set your fax device to forward a received fax to another destination by a fax, an email, or a server. If you are out of office, but have to receive the fax, this feature may be useful.
1
Use one of the following options to forward a received fax to another destination:
  • Press (Fax) > (Menu) > Fax Feature > Rcv. Forward > Forward to Fax > On or Forward on the control panel.
  • Press (Fax) > (Menu) > Fax Feature > Rcv. Forward > Fwd. to Email > On or Forward on the control panel.
  • Press (Fax) > (Menu) > Fax Feature > Rcv. Forward > Forward to PC > On or Forward on the control panel.
2
To set your fax device to print out a fax when fax forwarding has been completed, select Forward&Print.
3
Enter the destination fax number, email address, or PC address and press OK.
4
Enter the starting time and ending time, then press OK.
5
Subsequent received faxes will be forwarded to the specified fax machine.
Receiving a fax in the computer
  • This feature may not be available depending on your printer/fax device model, or optional goods installed (see "Features by model" in your printer's User Guide).
  • To use this feature, set the option on the control panel using one of these options:
    • Press (Fax) > (Menu) > Fax Feature > Rcv. Forward > Forward to PC > Forward or On on the control panel.
    • Press (Fax) > (Menu) > Fax Feature > Forward > PC > On on the control panel.
    • Or select Setup > Machine Setup > Next > Fax Setup > Forward > PC > On.
1
Open the Samsung Easy Printer Manager.
2
Select the appropriate printer/fax device from the Printer List.
3
Select Fax to PC Settings menu.
4
Use Enable Fax Receiving from Device to change the following fax settings.
  • Image Type: Convert the received faxes to PDF or TIFF.
  • Save Location: Select location to save the converted faxes.
  • Prefix: Select prefix.
  • Print received fax: Set to print information for the received fax after receiving the fax.
  • Notify me when complete: Set to show the popup window to notify when receiving a fax.
  • Open with default application: After receiving the fax, open it with default application.
  • None: After receiving a fax, the fax device does not notify the user, or opens the application.
5
Press Save > OK.
Changing the receive modes
1
Press (Fax) > (Menu) > Fax Setup > Receiving > Receive Mode on the control panel.
Or select Setup > Machine Setup > Next > Default Setting > Fax Default > Common > Receive Mode.
2
Select the option you want:
  • Fax: Answers an incoming fax call and immediately goes into the fax reception mode.
  • Tel: Receives a fax by pressing (On Hook Dial) and then (Start) button.
  • Ans/Fax: Is used when an answering machine is attached to your fax device. Your fax device answers an incoming call, and the caller can leave a message on the answering machine. If your fax device senses a fax tone on the line, the fax device automatically switches to Fax mode to receive the fax.
    To use the Ans/Fax mode, attach an answering machine to the EXT socket on the back of your fax device.
  • DRPD: You can receive a call using the Distinctive Ring Pattern Detection (DRPD) feature. Distinctive Ring is a telephone company service which enables a user to use a single telephone line to answer several different telephone numbers. For further details, see "Receiving faxes using DRPD mode" provided later in this document.
    The DRPD setting may not be available, depending on your country.
3
Press OK.
4
Receiving manually in Tel mode
You can receive a fax call by pressing (On Hook Dial) button, and then pressing (Start) when you hear a fax tone.
If your fax device has a handset, you can answer calls using the handset (see "Features by models" in your printer's User Guide).
Receiving in Answering Machine/Fax mode
To use this mode, you must attach an answering machine to the EXT socket on the back of your fax device. If the caller leaves a message, the answering machine stores the message. If your fax device detects a fax tone on the line, it automatically begins to receive the fax.
  • If you have set your fax device to this mode, and your answering machine is switched off, or no answering machine is connected to the EXT socket, your fax device automatically goes into Fax mode after a predefined number of rings.
  • If the answering machine has a user-selectable ring counter, set the answering machine to answer incoming calls within 1 ring.
  • If your fax device is in Tel mode, disconnect or switch Off the answering machine with the fax device. Otherwise, the outgoing message from the answering machine will interrupt your phone conversation.
Receiving faxes with an extension telephone
When you are using an extension telephone connected to the EXT socket, you can receive a fax from someone you are talking to on the extension telephone, without going to the fax device.
When you receive a call on the extension phone and hear fax tones, press the keys *9* on the extension phone. Your fax device receives the fax.
*9* is the remote receive code preset at the factory for your fax device. The first and the last asterisks are fixed, but you can change the middle number to whatever number you want.
While you are talking over the telephone connected to the EXT socket, copy and scan features are not available.
This setting may not be available, depending on your country.
The Distinctive Ring Pattern Detection (DRPD) feature is a telephone company service which enables a user to use a single telephone line to answer several different telephone numbers. This feature is often used by answering services who answer telephones for many different clients and need to know which number someone is calling in on to properly answer the phone.
1
Select (Fax) > (Menu) > Fax Setup > Receiving > DRPD Mode > Waiting Ring on the control panel.
Or select Setup > Machine Setup > Next > Default Setting > Fax Default > Common > Receive Mode > DRPD.
2
Call your fax number from another telephone.
3
When your fax device begins to ring, do not answer the call. The fax device requires several rings to learn the pattern.
When your fax device completes learning the ring pattern, the display shows Completed DRPD Setup. If the DRPD setup fails, Error DRPD Ring appears.
4
Press OK, when Error DRPD Ring appears, and start over from step 2.
  • DRPD must be set up again if you re-assign your fax number, or connect the fax device to a different telephone line.
  • After DRPD has been set up, call your fax number again to verify that your fax device answers with a fax tone. Then have a call placed to a different number assigned to that same line to make sure the call is forwarded to the extension telephone, or answering machine, plugged into the EXT socket.
Receiving in Secure Receiving mode
You may need to prevent your received faxes from being accessed by unauthorized people. Turn on Secure Receiving mode, then all incoming faxes go into memory. You can print the incoming faxes by entering a password you define.
To use the Secure Receiving Mode, activate the menu as follows: (Fax) > (Menu) > Fax Feature > Secure Receive on the control panel.
Or select Setup > Machine Setup > Next > Fax Setup > Secure Receive.
Printing received faxes
1
Select (Fax) > (Menu) > Fax Feature > Secure Receive > Print on the control panel.
Or select Setup > Machine Setup > Next > Fax Setup > Secure Receive > Print.
2
Enter a four-digit password (that you defined earlier for your fax device), and then press OK.
3
The machine prints all of the faxes stored in memory.
Printing faxes on both sides of the paper
  • Some menus may not appear on the display depending on options or models. If so, it is not applicable to your fax device.
1
2
Press (Fax) > (Menu) > Fax Setup > Receiving > Duplex Print on the control panel.
  • Off: Prints in Normal mode.
  • Long Edge: Prints pages to be read like a book.
  • Short Edge: Prints pages to be read by flipping like a note pad.
3
Press OK.
4
Receiving faxes in memory
Since your printer/fax device is a multi-tasking device, it can receive faxes while you are making copies or printing. If you receive a fax while you are copying or printing, your machine stores incoming faxes in its memory. Then, as soon as you finish copying or printing, the machine automatically prints the fax.
If a fax is received and being printed, other copy and print jobs cannot be processed at the same time.
Printing sent fax report automatically
You can set your fax device to print a report with detailed information about the previous 50 communication operations, including times and dates.
1
Use one of the following options to print a Sent Fax report:
  • Press (Fax) > (Menu) > Fax Setup > Auto Report > On on the control panel.
  • Press (Fax) > (Menu) > System Setup > Report > Fax Sent on the control panel.
2
