Samsung Xpress Color MFP SL-C480 - Loading Paper in the Tray
Illustrations on this user’s guide might differ from the printer depending on its options or models. Check the printer type, see Front view.
  1. Pull out the paper tray, see Tray overview.
    Figure : Remove tray
  2. Open the paper cover.
    Figure : Open cover
  3. Squeeze and the paper width guide and paper length lever to locate them in the correct paper size slot marked at the bottom of the tray to adjust to the size.
    Figure : Width and length guides
  4. Flex or fan the edge of the paper stack to separate the pages before loading papers.
    Figure : Flex or fan
  5. Place the paper with the side to print facing up.
    Figure : Paper face up
    For paper, smaller than A4-size, press and unlatch the guide lock in the tray, push the tray in manually. Then adjust the paper length guide and paper width guide.
    Figure : Paper, smaller than A4
    For paper, longer than Legal-size, press and unlatch the guide lock in the tray, pull the tray out manually. Then adjust the paper length guide and paper width guide.
    Figure : Paper, longer than Legal
    • Do not push the paper width guide too far causing the media to buckle.
    • Do not use a paper with a leading-edge curl, it might cause a paper jam or the paper can be wrinkled.
      Figure : No curl
    • Not adjusting the paper width guide, it might cause paper jams.
      Figure : Adjust width guides
  6. Squeeze the paper width guide and slide it to the edge of the paper stack without causing it to buckle.
    Figure : Adjust to paper size
  7. Close the paper cover.
    Figure : Close cover
  8. Insert the paper tray.
    Figure : Insert tray
  9. When printing a document, set the paper type and size for the tray. See Setting the paper size and type.
Tray presets
The tray is preset to Letter or A4 size, depending on the country. To change the size to A4 or Letter, adjust the lever and paper width guide properly.
  1. Pull the tray out of the printer. Open the paper cover and remove paper from the tray if necessary.
  2. To change the size to Letter, hold the lever at the back of the tray, and rotate the lever clockwise. The lever can be seen when moving the paper length guide to the legal sized paper (LGL).
    Figure : A4 to Letter
  3. Squeeze the paper width guide and slide it to the edge of the lever.
    To change the size to A4, first move the paper width guide to left and rotate the lever counterclockwise. Forcing the lever might damage the tray.
