    We are upgrading our website
HP ElitePOS G1 14-inch Touch AiO Retail System - Specifications
Operating systems
Feature
Operating systems
Windows 10 Pro 64-bit
Windows 10 IoT Enterprise 2016 LTSB 64-bit
FreeDOS 1.2
Certified
SUSE Linux 12 SP3 (certification planned for late 2017 on a single platform configuration)
Power management and multi-touch capabilities are not supported.
Systems configured with Linux do not qualify for ENERGY STAR.
In accordance with Microsoft support policy, this product does not support Windows 8 or Windows 7. HP does not support the Windows 8 or Windows 7 operating system on products configured with Intel 7th generation or later processors, or provide any Windows 8 or Windows 7 drivers.
Not all features are available in all editions or versions of Windows. Systems might require upgraded and/or separately purchased hardware, drivers, and/or software to take full advantage of Windows functionality. Windows 10 automatic updates are always enabled. ISP fees might apply and additional requirements might apply over time for updates.
Processors
Feature
Intel Core i5-7300U (model 143 and 145 - available November 2017)
2.60 GHz
3 MB cache, 2 cores
Supports Intel vPro technology and Intel Stable Image Platform Program (SIPP)
Intel Turbo Boost Technology
Intel Virtualization Technology (Intel VT)
Intel Active Management Technology (iAMT)
iAMT requires AMT-enabled chipset, network hardware and software, as well as connection with a power source and a corporate network connection.
Future virtual appliances applications dependent on third-party software and compatibility to be determined.
Intel Core i3-7100U (model 141)
2.4 GHz
3 MB cache, 2 cores
Intel Core Celeron 3965U
2.2 GHz
2 MB cache, 2 cores
Intel Multi-Chip Package (MCP)
Multicore is designed to improve performance of certain software products. Not all customers or software applications necessarily benefit from use of this technology. Performance and clock frequency vary depending on application workload and hardware and software configurations. Intel numbering is not a measurement of higher performance.
Graphics
Feature
Integrated graphics
Intel Integrated HD Graphics 610 (Celeron, for model 141)
Intel Integrated HD Graphics 620 (Core i3, for model 143)
Intel Integrated HD Graphics 620 (Core i5, for model 145)
DisplayPort
Multimode capable
Supports HDCP, DisplayPort audio (2 streams), HBR2 link rates and Multi-Stream technology for a maximum of 3 displays (including the integrated panel)
Memory
BIOS options (for selecting dedicated memory size)
128 MB, 256 MB, or 512 MB
Additional memory allocated for graphics as needed using Intel Dynamic Video Memory Technology (DVMT), to provide an optimal balance between graphics and system memory use.
Maximum memory
Windows 10 (> 4 GB)
The actual amount of maximum graphics memory can be less depending upon computer configuration.
Maximum color depth
32 bits/pixel
Graphics/video API support
DirectX Video Acceleration (DXVA) support for accelerating video processing
Advanced Scheduler 2.0, 1.0
Windows 10 and Linux OS support
DirectX 12.1
OpenGL 4.4
Open CL 1.2 (Intel HD Graphics 510)
Open CL 1.2/2.0 (Intel HD Graphics 530)
Supported resolutions
1920 x 1200 at 60 Hz
2048 x 1152 at 60 Hz
2048 x 1280 at 60 Hz
2048 x 1536 at 60 Hz
2304 x 1440 at 60 Hz
2560 x 1440 at 60 Hz
2560 x 1600 at 60 Hz
2880 x 1800 at 60 Hz
3200 x 2400 at 60 Hz
4096 x 2160 at 60 Hz
4096 x 2304 at 60 Hz
Only supported on displays connected to the external DisplayPort connector.
3840 x 2160 at 30 Hz (not supported for Celeron series processor)
640 x 480 at 60 Hz
800 x 600 at 60 Hz
1024 x 768 at 60 Hz
1280 x 720 at 60 Hz
1280 x 768 at 60 Hz
1360 x 768 at 60 Hz
1280 x 1024 at 60 Hz
1400 x 1050 at 60 Hz
1680 x 1050 at 60 Hz
1920 x 1080 at 60 Hz
Feature
General
35.56 cm (14 in) diagonal Wide-aspect operator value display , Anti-Glare WLED SVA (model 141)
35.56 cm (14 in) diagonal Wide-aspect projective capacitive operator display, Anti-Glare WLED UWVA (Models 143 and 145)
Dual microphone array
Touch technology
Projected capacitive touchscreen (models 141, 143, and 145)
Resolution
1920 x 1080
Aspect ratio
16:9
Maximum Color
262 K
Brightness (typical)
300 nits (LCM) (model 141)
500 nits (LCM) (model 143 and 145)
Contrast ratio (typical)
300:1 (model 141)
800:1 (model 143 and 145)
Pixel pitch
160.86 um x 160.86 um (model 141)
161.0 um x 161.0 um (model 143 and 145)
Viewing angle
Horizontal 90°, vertical 65° (model 141)
Horizontal 178°, vertical 178° (model 143 and 145)
Response rate (typical On/Off)
10 ms (model 141)
25 ms (model 143 and 145)
Backlight
LED (models 141, 143, and 145)
Operating temperature range
0 to 60°C (+60°C as panel surface temperature)
Storage/drives
Feature
M.2 SATA
128 GB M2 SATA-3 TLC
256 GB M2 SATA-3 TLC SSD
512 GB M2 SATA-3 TLC SSD
512 GB Turbo Drive G2 MLC SSD
NVMe
128 GB TLC 6000p SSD
256 GB PCIe NVMe TLC SSD
256 GB TLC Pro 6000p SSD
512 GB PCIe NVMe TLC SSD
512 GB TLC Pro 6000p SSD
1 TB PCIe-3x4 NVMe TLC SSD
Drive bays
(1) M.2 SSD bay
Memory
Feature
Memory
DDR4-2400 (transfer rates up to 2400 MT/s)
Actual supported data transfer rate determined by the configured processor.
(2) SODIMM slots supporting dual-channel memory (both slots are customer accessible/upgradeable)
Configurations
4 GB (4 GB x 1)
8 GB (4 GB x 2)
8 GB (8 GB x 1)
16 GB (8 GB x 2)
16 GB (16 GB x 1)
32 GB (16 GB x 2)
Maximum
32 GB
With Windows 32-bit operating systems, memory above 3 GB might not all be available due to system resource requirements. Addressing memory above 4 GB requires a 64-bit operating system.
Due to the non-industry standard nature of some third-party memory modules, we recommend HP branded memory to ensure compatibility. If memory speeds are mixed, the system performs at the lower memory speed.
Shut down the Retail System and disconnect the power cord before adding or removing memory modules. Regardless of the power-on state, voltage is always supplied to the memory modules as long as the Retail System is plugged in to an active AC outlet. Adding or removing memory modules while voltage is present might cause irreparable damage to the memory modules or system board.
Audio
Feature
Integrated
ElitePOS system audio (Realtek ALC3228)
HD stereo codec
ALC3228 High-Definition Audio Codec
Internal speaker
Yes, 1 W amplifier only
Sampling
All DACs support 44.1/48/96/192 kHz sample rate
All ADCs support 44.1/48/96/192 kHz sample rate
S/PDIF-OUT support 16/20/24-bit format and 32/44.1/48/88.2/96/192 kHz rate
Analog audio
Yes
Channels on Line-out
Stereo (left and right channels)
USB
Advanced and basic I/O base (Realtek ALC4040)
Audio codec
ALC4040 Audio Codec with USB to I2S audio controller
Hardware active noise cancellation
Audio I/O ports
(1) Headphone-out/microphone-in combo jack
Sampling
One I2S/PCM/TDM digital interface supports sample rates 8, 16, 32, 44.1, 48, 96, and 192 kHz
One stereo DAC supports up to 44.1, 48, and 192 kHz sample rate, 16/24-bit
One stereo ADC Input supports 44.1, 48, and 96 kHz sample rate, 16/24-bit
Analog audio
Yes
2
External speaker jack
1
Audio input ports are re-taskable as Line-in or Microphone-in port. External speakers must be powered externally. Multi-streaming can be enabled to allow independent audio streams to be sent to/from the internal speakers and headphone/Line-out jack. This allows for different audio applications to use separate audio ports on the system.
Ports/connectors/slots
Feature
Basic I/O connectivity
(1) Cash drawer connector
(1) Headset connector
(1) Power connector
(3) Serial ports
(1) USB Type-C port (charging)
(4) USB 2.0
(2) USB 3.0
(1) RJ-45
(1) Micro-SD card reader
(1) Security cable slot
Advanced I/O connectivity (available by November 2017)
(1) Power connector
(2) Powered serial ports
(4) USB 3.0
(2) Powered USB 12 V ports
(1) Powered USB 24 V ports
(1) RJ-45
Networking
Feature
Ethernet connection
Realtek RTL8153
PCIe GBE Ethernet family controller
WLAN (optional)
Intel Dual Band Wireless-AC 8265 802.11a/b/g/n/ac (2x2) WiFi and Bluetooth 4.2 combo (non-vPro and vPro)
Realtek 802.11b/g/n (1x1) WiFi and Bluetooth 4.0 combo
Bluetooth
HP Integrated module with Bluetooth 4.0 with Enhanced Data Rate (EDR) wireless technology
Wireless cards are optional or add-on features. Wireless access point and Internet service required and not included. Availability of public wireless access points limited. The specifications for the 802.11ac WLAN are draft specifications and are not final. If the final specifications differ from the draft specifications, it might affect the ability of the workstation to communicate with other 802.11ac WLAN devices.
Software/security
Feature
HP BIOSphere with Sure Start Generation 3.0
HP BIOSphere Gen3 requires Intel 7th generation processors.
HP Device Guard (not available with Windows 10 Pro)
Windows 10 Enterprise and Device Guard are only available for installation through HP Custom Integration Services to enterprise customers with a volume license to use Windows 10 Enterprise.
HP Support Assistant
HP Credential Guard
HP Point of Sale Diagnostics UEFI
Security
HP ElitePOS biometric fingerprint reader (optional)
Bolt to counter mechanism
VESA mounting
HP ElitePOS Keyed Cable Lock
Trusted Platform Module (TPM) 2.0 embedded security chip (SLB9670 - Common Criteria EAL4+ certified)
Drive lock
USB enable/disable (via BIOS)
Power-on password (via BIOS)
Setup password (via BIOS)
Tamper resistant screw affixed on stand of the system unit (used to secure display head to stand without Quick Release)
Power
Feature
Power supply
120 W for basic retail I/O connectivity base
88% efficient, active PFC (external)
180 W for advanced retail I/O connectivity base
89% efficient, active PFC (external)
65 W for display head unit only
89% efficient at 20 V, active PFC (external)
Operating voltage range
90 to 264 VAC
Rated voltage range
100 to 240 VAC
Rated line frequency
50 to 60 Hz
Operating line frequency range
47 to 63 Hz
Rated input current
< 2.2 A/120 W
< 2.52 A/180 W
< 1.7 A/65 W
Power cord length
(2) I/O Base cable options
(1) 45 cm (17.72 in) – when I/O Base is attached to Stand
(2) 1.8 m (70.87 in) – when I/O Base is detached or display head only
Physical specifications
Feature
Dimensions (W X D X H)
Head unit
33.60 x 21.61 x 1.75 cm (13.23 x 8.51 x 0.69 in)
Stand with column printer
9.57 x 9.57 x 25.91 cm (3.77 x 3.77 x 10.2 in)
Connectivity base
28.52 x 16.18 x 2.89 cm (11.23 x 6.37 x 1.14 in)
Rotate stand
1.33 kg (2.93 lb)
Fixed stand
1.09 kg (2.40 lb)
Head unit
1.38 kg (3.04 lb)
Connectivity base
0.56 kg (1.23 lb)
Printer
1.94 kg (4.28 lb)
Weight and dimensions not include the Magnetic Stripe Reader (MSR), Biometric reader, Webcam, or Customer Facing Display (CFD).
Upgrades
Feature
Upgrades (for product life extension)
(2) Memory slots
M.2 2230 slot for WLAN
(1) M.2 2280 slot for SSD
(4) USB ports (plug in ports for 2 bases)
(2) USB 2.0
(2) USB 3.0
(3) USB ports
Peripheral integration around display head (top, left, and right)
Environmental and certifications
Feature
Temperature
Operating
10 to 40°C (50 to 104°F)
Non-operating
-30 to 65°C (-22 to 149°F)
Relative humidity
Operating
20 to 85%
Altitude (unpressurized)
Operating
3,048 m (0 to 10,000 ft)
Non-operating
9,144 m (0 to 30,000 ft)
Eco-label certifications and declarations
IT ECO declaration
US ENERGY STAR
EPEAT Gold (registration varies by country/region)
Low Halogen
Country: Flag Vietnam
