HP Pavilion x360 - 14-ba017tx Product Specifications
1PM19PA
Intel® Core™ i5-7200U (2.5 GHz, up to 3.1 GHz, 3 MB cache, 2 cores)
8 GB DDR4-2133 SDRAM (1 x 8 GB)
Video graphics
NVIDIA® GeForce® 940MX (2 GB DDR3 dedicated)
128 GB M.2 SSD
14" diagonal FHD IPS UWVA WLED-backlit touch screen (1920 x 1080)
Keyboard
Full-size island-style backlit keyboard
Pointing device
Intel® 802.11a/b/g/n/ac (2x2) Wi-Fi® and Bluetooth® 4.2 Combo (Miracast compatible)
1 HDMI; 1 headphone/microphone combo; 1 USB 3.1 Type-C™ Gen 1 (Data up to 5 Gb/s); 2 USB 3.1 Gen 1 (Data transfer only)
Dimensions (W x D x H)
33.48 x 22.69 x 1.99 cm
1.63 kg
65 W AC power adapter
3-cell, 41 Wh Li-ion
Dual speakers; B&O PLAY; HP Audio Boost
HP 3D DriveGuard; HP ePrint; HP Recovery Manager; HP Support Assistant; HP Audio Switch; HP Sure Connect; HP JumpStart; HP Orbit
Pre-installed software
User Guide documentation; Dropbox
