HP Pavilion Power - 15-cb504tx Product Specifications
2LR99PA
Intel® Core™ i7-7700HQ (2.8 GHz base frequency, up to 3.8 GHz with Intel® Turbo Boost Technology, 6 MB cache, 4 cores)
Intel® HM175
Video graphics
NVIDIA® GeForce® GTX 1050 (4 GB GDDR5 dedicated)
1 TB 7200 rpm SATA
15.6" diagonal FHD IPS anti-glare WLED-backlit (1920 x 1080)
Keyboard
Pointing device
Intel® 802.11a/b/g/n/ac (2x2) Wi-Fi® and Bluetooth® 4.2 Combo
1 USB 3.1 Type-C™ Gen 1 (Data Transfer up to 5 Gb/s, DP1.2, HP Sleep and Charge); 3 USB 3.1 Gen 1 (1 HP Sleep and Charge); 1 HDMI; 1 RJ-45; 1 headphone/microphone combo
Dimensions (W x D x H)
37.8 x 25.22 x 2.41 cm
2.21 kg
150 W AC power adapter
4-cell, 70 Wh Li-ion
HP 3D DriveGuard; HP Audio Switch; HP ePrint; HP JumpStart; HP Orbit; HP Recovery Manager; HP Support Assistant; HP Sure Connect
