Samsung MultiXpress MFP SL-K2200 - Clearing Paper Jams
This document shows you how to clear a paper jam in the printer. When a paper jam occurs, a warning message appears on the display screen.
To avoid tearing the document, remove the jammed document slowly and gently.
Illustrations may differ from your machine depending on the model and options installed. Check your machine type. This troubleshooting may not be available depending on model or optional goods.
