Samsung ProXpress SL-M3820 - Using Linux Unified Driver Configurator
The Unified Driver Configurator is a tool primarily intended for configuring machine devices. You need to install Unified Linux Driver to use Unified Driver Configurator (see Installation for Linux in the User Guide ).
After the driver is installed on your Linux system, the Unified Driver Configurator icon will automatically be created on your desktop.
Opening Unified Driver Configurator
  1. Double-click the Unified Driver Configurator on the desktop. You can also click the Startup Menu icon and select Samsung Unified Driver > Unified Driver Configurator.
  2. Click each button on the left to switch to the corresponding configuration window.
      Figure : Example of the buttons
      Image shows the Printer and Port Configuration buttons
    1. Printer Configuration
    2. Port Configuration
  3. After changing the configurations, click Exit to close the Unified Driver Configurator.
