Samsung Xpress MFP SL-M2070, SL-M2071 - Install the Scan Driver for macOS X
Learn how to install the scan driver for Mac OS X with Samsung printers.
Figure : Example of Scan Installation folders for macOS X
Image shows Scan installation folders
To install the scan drivers, follow these steps in the order presented or click the link below that corresponds with your scan driver and then follow the steps to complete the scan installation.
ICDM
Use the following steps to install the scan driver.
  1. Open the Mac_ICDM Folder, and then run the ICDM Installer.
    Figure : Example of the Mac_ICDM folder
    Image shows ICDM Installer
  2. Click Continue on the Introduction dialog.
    Figure : Example of ICDM Installer for Mac, Introduction dialog
    Image shows the Welcome screen, and then clicking Continue
  3. On the Installation Type dialog, click Install to begin the installation process.
    Figure : Example of clicking on Install
    Screen shows selecting an installation destination
  4. Type your password to allow the installation, and then click Install Software.
    Figure : Example of entering the password
    Image shows enter the password, and then clicking Install Software
  5. To complete the installation process, click Close.
    Figure : Example of installation successfully completed
    Image shows installation complete screen
Twain
To install the Twain Driver, use the following steps.
  1. Open the Mac_Twain Folder, and then run the ScanThru.pkg file.
    Figure : Example of opening the Mac_Twain Folder
    Image shows the Mac_Twain folder
    Figure : Clicking Continue on the Introduction dialog
    Image shows welcome dialog
    Figure : Example of clicking Install on Installation Type dialog
    Image shows selecting an installation destination
    Figure : Example of Example of entering the password
    Image shows installation completed successfully
Scan Assistant
To install the Scan Assistant software, use the following steps.
  1. Open the Mac_Scan Assistant Folder, and then run the Scan Assistant.pkg file.
    Figure : Example of opening the Scan Assistant Installer folder
    Image shows the Scan Assistant Installer
    Figure : Example of the Scan Assistant Installer
  4. Enter your password to allow the installation, and then click Install Software.
    Figure : Example of the installation successfully completed
Scan Manager
To install the Scan Manager software, use the following steps.
  1. Open the Mac_ScanManager Folder, and then run the ScanManager Installer.pkg file.
    Figure : Example of Scan Manager Installer folder
    Image shows Scan Manager folder
  2. Click Continue on the Introduction Dialog.
    Figure : Example of clicking Continue
    Image shows clicking on Continue
  3. Select a destination where you want to install the Scan Manager software, and then click Continue.
    Figure : Example of selecting a destination for the Scan Manager software
    Image shows selecting a destination for software
  4. On the Installation Type dialog, click Install to begin the installation process.
    Figure : Example of Installation Type dialog, and then clicking Install
    Image shows installation type dialog
  5. Enter your password to allow the installation, and then click Install Software.
  6. To complete the installation process, and then click Close.
    Figure : Example of successfully installing software
    Image of complete of a successful installation
