Samsung Laser Printers - Clearing Original Document Jams
This document shows you how to clear original document jams. The original document jam can occur in front of the scanner, inside the scanner and in the exit area of the scanner. When a document jams while passing through the Automatic Document Feeder (ADF), a warning message appears on the display.
To prevent document jams, use the document glass for thick, thin, or mixed paper-type documents.
