Samsung Xpress MFP SL-M2885 - Supplies and Maintenance Parts
Available supplies
When supplies reach the end of their lifespans, the following supplies can be order for the machine:
Type
Model
Average yielda
Part name
Toner cartridge
M2670, M2671, M2870, M2880 series
Approx. 3,000 pages
MLT-D115L
M2675, M2676, M2875, M2876, M2885, M2886 series
Approx. 1,200 pages
MLT-D116Sb
Approx. 3,000 pages
MLT-D116L
Imaging unit
Approx. 9,000 pages
MLT-R116
a. Declared yield value in accordance with ISO/IEC 19752.
b. Not supported for India.
Available maintenance parts
Replace the maintenance parts at specific intervals to keep the machine in the best condition, and to avoid print quality and paper feeding problems resulting from the worn-out parts. Maintenance parts are mostly rollers, belts and pads. However, the replacement period and parts might differ depending on the model. Replacing maintenance parts can be performed only by an authorized service provider, dealer, or the retailer where the machine was purchased. To purchase maintenance parts, contact the retailer where the machine was purchased. The replacement period for the maintenance parts is informed by the Samsung Printer Status program. Or on the UI (user interface) if the machine supports a display screen. The replacement period varies based on the application software, paper type, paper size, and job complexity.
