Samsung Laser Printers - Easy Eco Driver
  • The Easy Eco Driver may not be available depending on your model of printer, or the optional goods installed. (See the Software section of your printer's User Guide to see which software options are available.)
  • The Easy Eco Driver is available for Windows OS users, only.
With the Easy Eco Driver, you can apply economy features to save paper and toner, before you begin printing.
Easy Eco Driver also allows you to do simple editing, such as removing images and texts, changing fonts, and more.
If you want to run Easy Eco Driver every time you print, go to Printer Properties (or Printing preference window, depending on your model) > Basic tab > and place a check mark the checkbox for Start Easy Eco Driver before printing job.
How to use Easy Eco Driver
  1. Open a document to print.
  2. Open the Printing preference window.
  3. From the Favorites tab, select Eco Printing Preview.
  4. Click OK > Print.
    A preview window appears.
  5. Select the options you want to apply to the document.
    A preview of the applied document features is displayed.
  6. Click Print.
