Samsung Laser Printers - Easy Capture Manager
  • Easy Capture Manage is available for Windows OS users, only.
  • Easy Capture Manager may not be available depending on your printer model, or optional printer goods installed. (Refer to the software options listed as available in your printer's User Guide).
Capture your screen and launch Easy Capture Manager by simply pressing the Print Screen key on the keyboard. Now you can easily print your captrued screen as captured or edited.
