HP Spectre x360 - 13-ac073tu Product Specifications
1PL74PA
Intel® Core™ i7-7500U (2.7 GHz base frequency, up to 3.5 GHz with Intel® Turbo Boost Technology, 4 MB cache, 2 cores)
16 GB LPDDR3-1866 SDRAM (onboard)
Video graphics
Intel® HD Graphics 620
512 GB PCIe® NVMe™ M.2 SSD
13.3" diagonal FHD UWVA BrightView WLED-backlit touch screen (1920 x 1080)
Keyboard
Full-size island-style backlit keyboard
Pointing device
Intel® 802.11ac (2x2) Wi-Fi® and Bluetooth® 4.2 Combo (Miracast compatible)
1 headphone/microphone combo; 2 USB 3.1 Type-C™ Gen 2 (Thunderbolt, Data up to 40 GB/s, Power Delivery, DP1.2, HP Sleep and Charge); 1 USB 3.1 Gen 1 (HP Sleep and Charge)
Dimensions (W x D x H)
30.7 x 21.8 x 1.39 cm
1.32 kg
65 W AC power adapter
3-cell, 57.8 Wh Li-ion
HP TrueVision FHD IR Camera with dual array digital microphone
Bang & Olufsen; HP Audio Boost; Quad speakers
Windows 10 Pro 64
HP ePrint; HP Recovery Manager; HP Support Assistant; HP Audio Switch; HP Sure Connect
Pre-installed software
User Guide documentation
