Samsung Laser Printers - How to Test the Paper in Your Printer
This printer model can print on 16 to 24 lb. paper from the main tray and 16 to 43 lb. paper from the manual tray. If printing on lighter or heavier paper, the printer will not function correctly.
To test the paper being used, follow these steps:
  1. Make sure the paper being used meets the requirements previously described.
  2. Open the paper tray and remove all but ten sheets of paper from the tray, then reinsert the tray.
    Before inserting the paper into the tray makes the pages are not stuck together by flexing and fanning them.
    Figure : Flex and fan
  3. Click Start on the bottom left of the screen.
  4. Click Control Panel, then Devices and Printers.
  5. Right click the name of the printer, then select Properties. A pop-up appears.
    Figure : Printers
  6. Click Print Test Page on the lower right of the pop-up.
    Figure : Properties
If the printer does not print, check the connection between the printer and PC.
If an error message appears on the printer or PC when trying to print the test page, see Error Messages and Status LEDs for help with the error being experienced.
