Samsung Laser Printers - How to Change a Printer's IP Information Using Samsung Set IP in Windows
Samsung network ready printers are shipped with a Samsung network printer utility CD included. Before using your printer, insert the CD into your PC, and then install all of the programs included on the CD. If you cannot locate, or do not have the CD available, go to Software and Driver Downloads to access the Samsung network printer utility programs included on the CD for your printer model.
If you have Easy Printer Manager installed, you can also go to Set IP by clicking the Set IP button at the bottom of the display, while Easy Printer Manager is in Advanced Mode.
Figure : In Easy Print Manager select Set IP
To setup your printer using the Set IP software, included on the CD with your printer, do the following steps:
  1. Open the Set IP program. The program will scan your network and list any Samsung printers it finds. If your printer does not appear in the list, make sure it is powered On, connected to the network, and in the same IP range as your router.
    Figure : Set IP lists printers available on your network
  2. Highlight the printer you want to network, and then click Manual Setting.
    Figure : Select printer to network and click Manual Setting
  3. Enter the Mac address of the printer (found on the Network Configuration Page) and enter the IP information that you desire to set, in the applicable fields, and then click Apply.
    For instructions on how to print a Network Configuration Page, refer to your user's manual.
    Figure : Set the IP information for your printer
  4. Click Exit to close the Set IP software.
