Samsung Laser Printers - How to Adjust Toner Save From the PC
Do the following to adjust the Toner Save option from your PC:
  1. Open Devices and Printers.
  2. Right click the printer corresponding with your PC, and then click Printing Preferences.
    Figure : Select the printer and click Printing Preferences
  3. When the Printing Preferences screen displays, click the Eco tab.
    Figure : Printing Preferences: click the Eco tab choice
  4. On the Eco tab screen, at the Eco Options\Type field, select one of the following, depending on your preference:
    • None
    • Eco Printing
    • Printer Default
    Figure : Select the Eco Options\Type preference
  5. Click the dropdown list for the Toner Save field, and then select the option Turned On or Turned Off.
    If the Toner Save dropdown list is grayed out, the option is turned off and is not available for the Eco Option\Type selected.
    Figure : In the Toner Save field select Turned On or Turned Off
  6. Click Apply, and then click OK to save the selections and changes made.
