OMEN by HP - 17-an014ur Product Specifications
2CM03EA
Intel® Core™ i7-7700HQ (2.8 GHz base frequency, up to 3.8 GHz with Intel® Turbo Boost Technology, 6 MB cache, 4 cores)
Intel® HM175
16 GB DDR4-2400 SDRAM (2 x 8 GB)
Video graphics
NVIDIA® GeForce® GTX 1050 (2 GB GDDR5 dedicated)
1 TB 7200 rpm SATA
Optical drive
DVD-Writer
43.9 cm (17.3") diagonal FHD IPS anti-glare WLED-backlit (1920 x 1080)
Keyboard
Pointing device
Intel® 802.11b/g/n/ac (2x2) Wi-Fi® and Bluetooth® 4.2 Combo
1 USB 3.1 Type-C™ (Data Transfer up to 5 Gb/s, DP1.2, HP Sleep and Charge); 3 USB 3.1 Gen 1 (1 HP Sleep and Charge); 1 Mini DisplayPort™; 1 HDMI; 1 RJ-45; 1 headphone/microphone combo; 1 microphone-in
42.3 x 30.4 x 3.3 cm
3.78 kg
150 W AC power adapter
8-cell, 82 Wh Li-ion
Bang & Olufsen; HP Audio Boost; Dual speakers
FreeDOS 1.2
