HP LaserJet Enterprise MFP M631, M632, M633 - Printer specifications
The following specifications are correct at the time of publication, but they are subject to change. For current information, see www.hp.com/support/ljM631MFP, www.hp.com/support/ljM632MFP, or www.hp.com/support/ljM633MFP.
Technical specifications
Model name
M631dn, M632h
K0Q14A, K0Q17A
M631h, M632fht, M633fh
K0Q15A, K0Q18A, K0Q21A
M631z, M632z, M633z
K0Q19A, K0Q22A
Paper handling
Tray 1 (100-sheet capacity)
Tray 2 (550-sheet capacity)
1x550-sheet paper feeder
The printer supports as many as six input trays.
Optional
Optional
Optional (not available for M631z)
1x550-sheet feeder plus 2,100-sheet high-capacity feeder
Optional
Optional
Included with the M632z and M633z
Automatic duplex printing
Envelope feeder cassette for printing up to 75 envelopes
Optional
Optional
Optional
HP Stapling Mailbox
Not supported
Not supported
Connectivity
10/100/1000 Ethernet LAN connection with IPv4 and IPv6
Hi-Speed USB 2.0
Easy-access USB port for printing and scanning without a computer and upgrading the firmware
Hardware integration pocket (HIP) for connecting accessories and third-party devices
HP Internal USB ports
Optional
Optional
Optional
HP Jetdirect 3000w NFC/Wireless Accessory for printing from mobile devices
Optional
Optional
Optional
Integrated HP Wi-Fi Direct accessory for printing from mobile devices
Not supported
Not supported
M631z and M633z
HP Jetdirect 2900nw Print Server Accessory for wireless connectivity
Optional
Optional
Optional
Internal Storage
16 GB eMMC hard drive
M631dn
Not supported
Not supported
320 GB HP High-Performance Secure Hard Disk
Included with the M632h; optional for the M631dn
Memory
1.75 GB base memory, expandable to 2.5 GB
Not supported
2.25 GB base memory, expandable to 3 GB
Not supported
Not supported
Security
HP Trusted Platform Module for encrypting all data that passes through the printer
Optional
Optional
Optional
Control-panel display and input
Touchscreen control panel
Retractable keyboard
Not supported
Not supported
Print
Prints 52 pages per minute (ppm) on A4 and 55 ppm on letter-size paper
M631dn
M631h
M631z
Prints 61 ppm on A4 and 65 ppm on letter-size paper
M632h
M632fht
M632z
Prints 71 ppm on A4 and 75 ppm on letter-size paper
Not supported
M633fh
M633z
Easy-access USB printing (no computer required)
Fax
Optional
Included with M632fht, M633fh; optional for the M631h
Copy and scan
Copy and scan speeds are subject to change. For the most current information, go to www.hp.com/support/ljM631MFP, www.hp.com/support/ljM632MFP, or www.hp.com/support/ljM633MFP
Copies 52 pages per minute (ppm) on A4 and 55 ppm on letter-size paper
M631dn
M631h
M631z
Copies 61 ppm on A4 and 65 ppm on letter-size paper
M632h
M632fht
M632z
Copies 71 ppm on A4 and 75 ppm on letter-size paper
M633fh
M633z
Scans at 75 images per minute (ipm) (monochrome or color).
Scans at 120 ipm (monochrome and color).
Easy-access USB copying and scanning (no computer required)
150-page document feeder with electronic duplex copying and scanning
HP EveryPage Technologies including ultrasonic multi-feed detection
Not supported
Not supported
Embedded optical character recognition (OCR) provides the ability to convert printed pages into text that can be edited or searched using a computer.
Not supported
Not supported
SMART Label feature provides paper-edge detection for automatic page cropping
Not supported
Not supported
Automatic page orientation for pages that have at least 100 characters of text.
Not supported
Not supported
Automatic tone adjustment sets contrast, brightness, and background removal for each page.
Not supported
Not supported
Digital Send
Send to E-mail, Save to USB, and Save to Network Folder
Send documents to SharePoint®
Not supported
Not supported
Supported operating systems
The following information applies to the printer-specific Windows PCL 6 and HP print drivers for OS X and to the software installer.
Windows: The HP Software Installer installs the “HP PCL.6” version 3 print driver, the “HP PCL 6” version 3 print driver, or the “HP  PCL-6” version 4 print driver, depending on the Windows operating system, along with optional software when using the software installer. Download the "HP PCL.6" version 3 print driver, the "HP PCL 6" version 3 print driver, and the "HP PCL-6" version 4 print driver from the printer-support website for this printer: www.hp.com/support/ljM631MFP, www.hp.com/support/ljM632MFP, or www.hp.com/support/ljM633MFP.
OS X: Mac computers are supported with this printer. Download HP Easy Start either from 123.hp.com/LaserJet or from the Printer Support page, and then use HP Easy Start to install the HP print driver. HP Easy Start is not included in the HP Software Installer.
  1. Follow the steps provided to download the printer software.
Linux: For information and print drivers for Linux, go to www.hp.com/go/linuxprinting.
UNIX: For information and print drivers for UNIX®, go to www.hp.com/go/unixmodelscripts.
Supported operating systems and print drivers
Print driver (for Windows, or the installer on the web for OS X)
Notes
Windows® XP SP3, 32-bit
The “HP PCL.6” printer-specific print driver is installed for this operating system as part of the software installation.
Microsoft retired mainstream support for Windows XP in April 2009. HP will continue to provide best effort support for the discontinued XP operating system. Some features of the print driver are not supported.
Windows Vista®, 32-bit
Microsoft retired mainstream support for Windows Vista in April 2012. HP will continue to provide best effort support for the discontinued Vista operating system. Some features of the print driver are not supported.
Windows Server 2003 SP2, 32-bit
The “HP PCL.6” printer-specific print driver is available for download from the printer-support website. Download the driver, and then use the Microsoft Add Printer tool to install it.
Microsoft retired mainstream support for Windows Server 2003 in July 2010. HP will continue to provide best effort support for the discontinued Server 2003 operating system. Some features of the print driver are not supported.
Windows 7, 32-bit and 64-bit
The “HP PCL 6” printer-specific print driver is installed for this operating system as part of the software installation.
Windows 8, 32-bit and 64-bit
Windows 8 RT support is provided through Microsoft IN OS Version 4, 32- bit driver.
Windows 8.1, 32-bit and 64-bit
The “HP PCL-6” V4 printer-specific print driver is installed for this operating system as part of the software installation.
Windows 8.1 RT support is provided through Microsoft IN OS Version 4, 32- bit driver.
Windows 10, 32-bit and 64-bit
Windows Server 2008 SP2, 32-bit
Microsoft retired mainstream support for Windows Server 2008 in January 2015. HP will continue to provide best effort support for the discontinued Server 2008 operating system. Some features of the print driver are not supported.
Windows Server 2008 SP2, 64-bit
The “HP PCL 6” printer-specific print driver is available for download from the printer-support website. Download the driver, and then use the Microsoft Add Printer tool to install it.
Windows Server 2008 R2, SP 1, 64-bit
Windows Server 2012, 64-bit
The PCL 6 printer-specific print driver is available for download from the printer-support website. Download the driver, and then use the Microsoft Add Printer tool to install it.
Windows Server 2012 R2, 64-bit
OS X 10.10 Yosemite, OS X 10.11 El Capitan, OS X 10.12 Sierra
The HP print driver is available for download from 123.hp.com/LaserJet. The HP installer software for OS X is not included in the HP Software Installer.
For OS X, download the installer from 123.hp.com/LaserJet.
For a current list of supported operating systems, go to www.hp.com/support/ljM631MFP, www.hp.com/support/ljM632MFP, or www.hp.com/support/ljM633MFP for HP's all-inclusive help for the printer.
For details on client and server operating systems and for HP UPD driver support for this printer, go to www.hp.com/go/upd. Under Additional information, click the links.
Minimum system requirements
Windows
OS X
  • CD-ROM drive, DVD drive, or an Internet connection
  • Dedicated USB 1.1 or 2.0 connection or a network connection
  • 400 MB of available hard-disk space
  • 1 GB RAM (32-bit) or 2 GB RAM (64-bit)
  • Internet connection
  • 1 GB of available hard-disk space
Mobile printing solutions
HP offers multiple mobile and ePrint solutions to enable easy printing to an HP printer from a laptop, tablet, smartphone, or other mobile device. To see the full list and to determine the best choice, go to www.hp.com/go/LaserJetMobilePrinting.
Update the printer firmware to ensure all mobile printing and ePrint capabilities are supported.
  • Wi-Fi Direct (wireless models only)
  • HP ePrint via email (Requires HP Web Services to be enabled and the printer to be registered with HP Connected)
  • HP ePrint app (Available for Android, iOS, and Blackberry)
  • HP All-in-One Remote app for iOS and Android devices
  • HP ePrint software
  • Google Cloud Print
  • AirPrint
  • Android Printing
Printer dimensions
Dimensions for base models (M631dn, Flow M631h, M632h, M633fh)
Printer fully closed
Printer fully opened
1–Height
640 mm
865 mm
2–Width
512 mm
1,030 mm
3–Depth
558 mm
805 mm
Weight (with toner cartridge)
32.4 kg
Dimensions for M632fht
1–Height
1,094 mm
1,365 mm
2–Width
665 mm
1,030 mm
3–Depth
600 mm
890 mm
51.0 kg
Dimensions for M631z, Flow M632z, Flow M633z
1–Height
1,234 mm
1,500 mm
2–Width
661 mm
1,030 mm
3–Depth
658 mm
890 mm
M631z Weight (with toner cartridge)
65.1 kg
Flow M632z and Flow M633z Weight (with toner cartridge)
62.6 kg
Dimensions for the 1x550-sheet paper feeder
Accessory fully closed
Accessory fully opened
1–Height
148 mm
148 mm
2–Width
512 mm
617 mm
3–Depth
558 mm
869 mm
6.8 kg
Dimensions for the printer with a 1x550-sheet paper feeder
Height
766 mm
1,010 mm
Width
512 mm
1,030 mm
Depth
558 mm
890 mm
39.2 kg
Dimensions for the 1x550-sheet feeder with printer stand
1–Height
478 mm
478 mm
2–Width
660 mm
980 mm
3–Depth
658 mm
1,050 mm
18.6 kg
Dimensions for the printer with a 1x550-sheet feeder with printer stand
Height
1,094 mm
1,365 mm
Width
665 mm
1,030 mm
Depth
600 mm
890 mm
51 kg
Dimensions for the 1x550/2000-sheet HCI Feeder & Stand
1–Height
478 mm
478 mm
2–Width
660 mm
980 mm
3–Depth
658 mm
975 mm
25.2 kg
Dimensions for the printer with a 1x550/2000-sheet HCI Feeder & Stand
Height
1,090 mm
1,360 mm
Width
660 mm
1,030 mm
Depth
658 mm
890 mm
57.6 kg
Dimensions for the envelope feeder cassette
1–Height
148 mm
148 mm
2–Width
512 mm
617 mm
3–Depth
558 mm
869 mm
6.8 kg
Dimensions for the printer with an envelope feeder
Height
766 mm
1,010 mm
Width
512 mm
1,030 mm
Depth
558 mm
890 mm
39.2 kg
Dimensions for the printer with an HP Stapling Mailbox
Height
779 mm
890 mm
Width
512 mm
1,030 mm
Depth
558 mm
890 mm
39.8 kg
Power consumption, electrical specifications, and acoustic emissions
Power requirements are based on the country/region where the printer is sold. Do not convert operating voltages. This will damage the printer and void the printer warranty.
Operating environment range
Environment
Recommended
Allowed
Temperature
17° to 25°C
15° to 32.5°C
Relative humidity
30% to 70% relative humidity (RH)
10% to 80% RH
Altitude
Not applicable
0 to 3048 m
Country: Flag Vietnam
