Samsung Laser Printers - How to Install a Printer Driver for Mac OS X
The Samsung Printer Software Installer is a web-based installer that will download and install the printer drivers and software required for Samsung printers.
If you have not installed the print driver yet, go to Software and Driver Downloads and enter your model printer into the search text box to download the latest driver.
To install the Print Driver, use these steps.
  1. In Downloads, open the Mac_Installer folder.
  2. Open the Mac_Printer Folder and run the Printer Driver Package Installer.
    Figure : Example of Printer Driver Package Installer
    Image shows Printer Driver Package Installer
    You might receive one of the following notifications:
    • If you receive a notification to Authenticate, enter the password, and then click OK, to continue.
    • If you receive a notification to Authenticate, and you do not know the password, contact your system administrator for assistance.
  3. Click Continue on the warning dialog, and then Continue in the printer driver window to start the installation program.
    Figure : Example of clicking Continue on the warning dialog box
    Image shows Warning dialog box and clicking continue
  4. Click Continue on the Introduction and Read Me dialogs, and then click Agree, to accept terms and conditions.
    Figure : Example of selecting Agree
    Image shows where to select Agree
  5. Close out all the applications, and then click Continue on the warning notification dialog that appears.
    Image shows example of clicking Continue
  6. Select where you want to install the printer driver software, and then click Continue.
    Figure : Example of selecting a destination
    Image shows selecting a destination
  7. Select the installation type, then click Install.
    Figure : Example shows clicking Install
    Image shows clicking on Install
  8. Enter your password if prompted to start installation.
    Figure : Example shows entering password to start installation
    Image shows entering password to install software
  9. The loading screen shows a progress bar.
    Figure : Image shows example of running package scripts
  10. Once complete, click Close to finish.
    Figure : Example of installation successfully completed
    Image shows installation complete and successfully connected
  11. To verify if the installation was successful, go to System Preferences.
    Figure : Example shows opening System Preferences
    Image shows opening System Preferences
  12. Click on Print & Scan.
    Figure : Example of Systems Preferences and Print & Scan
    Image shows clicking on Print & Scan in System Preferences
  13. The desired printer displays in the Printers list.
    Figure : Example of Printers list in Print & Scan
    Image shows Print & Scan dialog box with Printers list
