Samsung Laser Printers - Configure the Printer Through Smart Panel
Smart Panel has a built-in utility for changing printer settings. To launch Smart Panel and change the printer settings, use these steps.
  1. Right click on the Smart Panel icon. (The blue S in the system tray).
    Figure : Example of Smart Panel
  2. Click on Printer Settings in the context menu. A page like the following image will appear where you can change printer settings.
    Figure : Example of Printer Settings Utility
  3. Click Apply when you are done to apply the settings.
