Printer Specifications for HP Sprocket 2-in-1s
This document is for HP Sprocket 2-in-1s.
Review this document for detailed technical data, such as product numbers, mobile system requirements, print speeds, connectivity types, physical dimensions, power supply, paper handling, and printing specifications.
HP Sprocket 2-in-1
Printer specifications
Specification
Product numbers
2FB96A (White)
2FB97A (Black)
2FB98A (Red)
Dimensions and weight
122 x 77.42 x 28.96 mm (4.8 x 3.05 x 1.14 in)
0.191 kg (0.42 lb)
Connectivity
Bluetooth 3.0
Printer management
HP sprocket app
Power supply
Up to 35 prints per charge
Internal rechargeable battery
Two-cell 850 mAh Li-Polymer 7.4 V
Charge time
Up to 120 minutes
Power consumption
0.9 W (standby)
Average 15.91 W (based on first print)
Maximum 34.49 W at 25° C (77° F)
Print technology
Thermal printing with a ZINK® Zero Ink® printer
The sprocket does not use ink cartridges to print.
Supported paper
HP Sprocket Photo Paper
5.0 x 7.6 cm (2 x 3 in)
Borderless printing
Yes
Support file types
BMP
GIF
JPEG
PNG
TIFF (iOS only)
If you send a non-supported file type, the print job does not print.
Paper tray capacity
Up to 10 pages with the blue Print Quality Card (formerly Smartsheet)
Speaker
Yes
Tripod compatible
Yes
Selfie mirror
Yes
Self-timer
Yes, 10 seconds
Viewfinder
Smartphone printer mode
Instant camera toggle
Memory card compatibility
microSD card slot
Up to 256 GB
Print quality
313 x 400 dots per inch (dpi)
Print speed
Up to 40 seconds
Camera and lens
5 MP
LED dual color flash
Minimum focus distance: 0.7 m (2.29 ft) maximum
Mobile operating systems and devices
Supported by Android mobile devices with OS 4.4 and later, and iOS 9.0 and later
Compatible with Apple iPhone X, iPhone 8, iPhone 8 Plus, iPhone 7, iPhone 7 Plus, iPhone SE, iPhone 6x, iPhone 6s Plus, iPhone 6, iPhone 6 Plus, iPhone 5s, iPhone 5c, iPhone 5, iPad Pro 12.9-inch (2nd generation), iPad Pro 10.5-inch, iPad (5th generation), iPad Pro 9.7-inch, iPad Pro 12.9-inch (1st generation), iPad Air 2, iPad Air, iPad mini 2, iPad mini 3, iPad mini 4, iPad (4th generation), and iPod touch (6th generation)
Control panel
Power button
Reset button
Shutter release button
Timer button
Viewfinder
User interface
Charging Indicator light
Status Indicator light
Repeater Indicator light
SD card Indicator light
Environmental parameters
Operating humidity: 5% to 70% RH (recommended)
Non-operating humidity: 5% to 90% RH
Operating temperature: 5° to 40° C (41° to 104° F)
Recommended operating temperature: 15° to 32° C (59° to 90° F)
Storage temperature: -30° to 60° C (-22° to 140° F)
One-year limited hardware warranty
Visit the HP Sprocket homepage for more information.
Regulatory model number
For regulatory identification purposes, your product is assigned a Regulatory Model Number. The Regulatory Model Number for your product is VCVRA-1714. This regulatory number should not be confused with the marketing name (HP Sprocket 2-in-1) or product numbers (2FB97A, 2FB96A, and 2FB98A).
Material Safety Data Sheets
To view Material Safety Data Sheets (MSDS), go to http://www.hp.com/go/msds (in English).
Ozone production
This product generates no appreciable ozone gas (O3).
Recycling program
HP offers an increasing number of product return and recycling programs in many countries and regions, and partners with some of the largest electronic recycling centers throughout the world. HP conserves resources by reselling some of its most popular products. For more information about the recycling of HP products, go to www.hp.com/go/recycle (in English).
