Samsung Xpress MFP SL-M2070FW - The Incoming Fax has Incorrect Words or is Stretched
If your fax printer receives a fax with incorrect words or stretched lettering, the fax machine that is sending the document has a document jam. Inform the sender that their fax machine has a temporary document jam and they need to resend the fax.
