HP Pavilion - 15-cc747tx Product Specifications
2GE13PA
Intel® Core™ i7-7500U (2.7 GHz base frequency, up to 3.5 GHz with Intel® Turbo Boost Technology, 4 MB cache, 2 cores)
8 GB DDR4-2133 SDRAM (1 x 8 GB)
Video graphics
NVIDIA® GeForce® 940MX (4 GB DDR3 dedicated)
  • 1 TB 5400 rpm SATA
  • 128 GB M.2 SSD
15.6" diagonal FHD IPS BrightView WLED-backlit (1920 x 1080)
Keyboard
Pointing device
Intel® 802.11b/g/n/ac (1x1) Wi-Fi® and Bluetooth® 4.2 Combo
1 USB 3.1 Type-C™ Gen 1 (Data Transfer up to 5 Gb/s); 2 USB 3.1 Gen 1 (Data transfer only); 1 HDMI; 1 RJ-45; 1 headphone/microphone combo
37.8 x 25.21 x 1.99 cm
2.02 kg
65 W AC power adapter
3-cell, 41 Wh Li-ion
B&O PLAY; HP Audio Boost; Dual speakers
HP 3D DriveGuard; HP Audio Switch; HP Documentation; HP ePrint; HP JumpStart; HP Orbit; HP Recovery Manager; HP Support Assistant; HP Sure Connect
