    Find Windows 11 and Windows 10 support help. Click here
HP 24y 23.8-inch Display - Product Specifications
The HP 24y is a 60.5 cm (23.8 in) Display.
Figure : HP 24y Display
The HP 24y Display
1PX48AA
Technical specifications
LED feature
Specification
Display size
60.5 cm (23.8 in) diagonal
Display type
IPS
Brightness
250 nits
Pixel pitch
0.2745 mm (H) x 0.2745 mm (W)
93 PPI
Color gamut
72%
Color support
Up to 16.7 million colors
Frequency
Horizontal: 30-80 kHz
Vertical: 50-60 Hz
Inputs
1 VGA
1 DVI-D
1 HDMI
HDCP support on digital inputs
Viewing angle
Horizontal viewing angle (typical): 178 degrees
Vertical viewing angle (typical): 178 degrees
Resolution (recommended)
1920 x 1080 @ 60 Hz
Aspect ratio
16:9
Static contrast ratio
Up to 1000:1
Dynamic contrast ratio
Up to 10,000,000:1
Response time
8 ms (GtG)
Power consumption
25 W max
Tilt
-5 to +20 degrees
Dimensions
W x D x H (unpacked):
54.7 x 21.0 x 40.5 cm (21.5 x 8.3 x 16.0 in)
Unpacked: 3.7 Kg (8.1 lb)
