OMEN by HP - 15-ce004na Product Specifications
1RJ99EA
Intel® Core™ i5-7300HQ (2.5 GHz base frequency, up to 3.5 GHz with Intel® Turbo Boost Technology, 6 MB cache, 4 cores)
Intel® HM175
Video graphics
  • NVIDIA® GeForce® GTX 1050 (2 GB GDDR5 dedicated)
  • Discrete
1 TB 7200 rpm SATA
39.6 cm (15.6") diagonal FHD IPS anti-glare WLED-backlit (1920 x 1080)
Keyboard
Pointing device
Intel® 802.11b/g/n/ac (2x2) Wi-Fi® and Bluetooth® 4.2 Combo
1 USB 3.1 Type-C™ (Data Transfer up to 5 Gb/s, DP1.2, HP Sleep and Charge); 3 USB 3.1 Gen 1 (1 HP Sleep and Charge); 1 HDMI; 1 RJ-45; 1 headphone/microphone combo; 1 microphone-in
38.85 x 27.55 x 2.48 cm
2.62 kg
150 W AC power adapter
4-cell, 70 Wh Li-ion
Bang & Olufsen; HP Audio Boost; Dual speakers
HP Audio Switch; HP JumpStart; HP Sure Connect; HP CoolSense; HP Orbit
Pre-installed software
Netflix
1 month trial for new Microsoft® Office 365 customers
