HP USB Premium Keyboard - Specifications
Product specifications
Specification
Connectivity
USB interface
Cable length
1.8 m (5.90 ft)
Switches
Function lock switch
Access the special function keys without having to first press on the Fn key
On (Green)
Performs the action as depicted in the icon
Off (Red)
Hold the Fn key and the numeral function key to perform the action as depicted in the icon
Keys
109 (US) layout
110 (EU) layout
114 (JP) layout
Varies by country/region.
Feature summary
Anodized aluminum-trimmed full-size keyboard with numerical pad and 12 function keys
Adjustable slope
0 to 6°
Key force
60 ± 10 g
Key life
10 million cycles activation (Normal key)
Key typing noise
Maximum 55 dbA
Key structure
Scissor type
Key cap legend
Printed
Illuminated keys
Microphone mute (Amber)
Audio mute (Amber)
Caps Lock
Num Lock
Function keys
Fn + F1 – System sleep
Fn + F2 – System lock
Fn + F3 – File Explorer
Fn + F4 – Display options
Fn + F5 – Down brightness adjustment
Fn + F6 – Up brightness adjustment
Fn + F7 – Blank
Fn + F8 – Search
Fn + F9 – Devices
Fn + F10 – Print Screen
System requirements
Available USB port
Windows 7, Windows 8.x, and Windows 10
Screen brightness functions supported in select HP systems.
Operating temperature
0° to 40° C (32° to 104° F)
Service and support
One-year limited warranty
Physical specifications
Specification
Dimensions
432.82 x 11.68 x 140.97 mm (17.04 x 0.46 x 5.55 in)
680.39 g (1.5 lb)
Kit contents
Specification
Kit contents
Keyboard
Documentation
Approvals and certifications
Specification
Approvals
CE RF test report
USA/FCC Part 15 C
Canada/RS- 210
Argentina
Jordan
Russia-FAC (RF), Russia-CU
South Africa
Turkey
Ukraine
Brazil
Mexico
Australia/New Zealand RCM, Australia/New Zealand RF
China SRRC
India wireless, India safety
Indonesia
Japan TELEC
Korea KCC
Malaysia
Pakistan
Philippines
Singapore
Taiwan BSMI, Taiwan NCC
CB for Nemko
cCSAus for CSA
UL/CUL
GS for TUV Rh
Japan EMC
WHQL Win 10
