Remove and Replace the Left Side Cover on HP OMEN 880 Gaming PC
This document applies to HP OMEN 880 Gaming PCs.
Before you begin
  • Have available a Phillips-head screwdriver.
  • Turn off the computer. Disconnect the Ethernet or modem cable. Disconnect the power cord.
  warning:
Make sure the computer is disconnected from power before starting. Before starting, power off the computer and wait for components to cool before starting these procedures.
This product contains components that can be damaged by electrostatic discharge (ESD). To reduce the chance of ESD damage, work over a non-carpeted floor, use a static dissipative work surface (such as a conductive foam pad), and wear an ESD wrist strap connected to a grounded surface.
Procedures in this document are provided by HP for qualified service agents and as a courtesy to its customers. Servicing internal components increases the risk of damaging the computer which might not be covered under warranty. Understand the risk and refer to the product's warranty before attempting to service the computer.
Video overview
Removing the left side cover
To remove the left side cover, use the following instructions:
Step 1
Remove the Philips #2 screw for the rear locking latch of the cover if a screw is installed.
Removing the screw in the locking latch
Step 2
Slide the locking latch for the cover to the left unlocked stenciled position.
Sliding the locking latch to the left
Step 3
Press down very firmly on the release button at the top rear of the unit until the top of the left side cover releases.
Pressing down the release button
Step 4
Pull the top of the left side cover away slightly from the unit...
... and lift the bottom up to fully disengage the left side cover from the unit.
 Lifting the bottom up to fully disengage the left side cover
Replacing the left side cover
Use the following instructions to replace the left side cover:
Step 1
There is a lip along the bottom inside of the left side cover that...
The lip along the bottom of left cover
... aligns over a lip on the bottom inside of the PC.
The lip along the bottom PC
Step 2
There are also three tabs on the top inside of the left side cover that ...
Three tabs on the top inside of the left side cover
... slide into slots at the top inside of the PC.
The slots at the top inside of the PC
Step 3
To replace the left side cover, carefully align the bottom lip of the cover over the lip on the PC.
Aligning the lip on the cover with the lip on the PC
Step 4
Swing the top of the cover and press until it snaps into place.
Pressing the top of the cover to snap it into place
Step 5
Slide the locking latch for the left side cover to the right stenciled locked position.
Sliding the locking latch to the lock position
Step 6
Replace the Philips #2 screw for the locking latch if it was installed at removal.
Replacing the screw in the locking latch
