OMEN by HP 15-ax233nf Laptop PC Product Specifications
1TQ01EA
Intel® Core™ i5-7300HQ (2.5 GHz base frequency, up to 3.5 GHz with Intel® Turbo Boost Technology, 6 MB cache, 4 cores)
Intel® HM175
8 GB DDR4-2400 SDRAM (2 x 4 GB)
Video graphics
NVIDIA® GeForce® GTX 1050 (2 GB GDDR5 dedicated)
1 TB 7200 rpm SATA
39.6 cm (15.6") diagonal FHD IPS UWVA anti-glare WLED-backlit (1920 x 1080)
Keyboard
Pointing device
Intel® 802.11b/g/n/ac (2x2) Wi-Fi® and Bluetooth® 4.2 Combo
Integrated 10/100/1000 Gigabit Ethernet LAN
1 HDMI; 1 headphone/microphone combo; 1 USB 2.0; 2 USB 3.1 Gen 1, 1 RJ-45
38.2 x 25.3 x 2.45 cm
2.2 kg
150 W AC power adapter
4-cell, 63.3 Wh Li-ion
HP Wide Vision HD Camera with dual array digital microphone
Bang & Olufsen; HP Audio Boost; Dual speakers
HP Audio Switch; HP CoolSense; HP JumpStart
Pre-installed software
Netflix
