This document is for the HP DeskJet Ink Advantage 5275, 5276 and 5278, and OfficeJet 5212, 5220, 5222, 5230, 5232, 5252, 5255, 5258, and 5264 All-in-One printers.
To set up a printer for the first time, remove the printer and all packing materials from the box, connect the power cable, set control panel preferences, load paper into the input tray, install the ink cartridges, and then download and install the printer software.
note:If you are looking for the printer software, go to:
