    Windows 11 Upgrade Guide
HP N223v 21.5-inch Monitor Product Specifications
Product description
Figure : HP N223v 21.5-inch Monitor
Product features
Specification
Dimensions (W × D × H)
Unpacked with stand
50.39 x 17.04 x 38.30 cm (19.84 x 6.71 x 15.08 in)
Packed
57.0 x 10.69 x 38.51 cm (22.44 x 4.21 x 15.16 in)
Unpacked without stand
50.39 x 4.90 x 31.04 cm (19.84 x 1.93 x 12.22 in)
Unpacked with stand
2.60 kg (5.73 lb)
Packed
3.64 kg (8.02 lb)
Head only
2.46 kg (5.42 lb)
Panel
Specification
Type
21.5-inch, TN
54.61 cm (21.5 in) widescreen
Panel active area (W x H)
47.65 x 26.80 cm (18.76 x 10.55 in)
Resolution
1920 x 1080 at 60 Hz
Aspect ratio
16:9
Viewing angle (typical)
Up to 90° horizontal
Up to 65° vertical
Brightness
200 cd/m2
Contrast ratio
450:1 static (minimum)
600:1 static (typical)
Dynamic contrast ratio
10,000,000:1 dynamic (DCR)
Response times
5 ms
Pixel pitch
0.248 x 0.248 mm
Pixels Per Inch (PPI)
102
Default color temperature
6500 K
Backlight lamp life
30,000 hours minimum (to half brightness)
Panel bit depth
8-bit (6-bit + Hi FRC)
Color gamut (typical)
72% (NTSC)
Anti-glare panel
Yes
Actual performance varies.
User controls
Specification
Buttons or switches
Menu, Minus ("-"), Plus ("+") /Input Control, and Power
User Programmable Modes
Yes, 3 (6 options)
Languages
10 (English, Spanish, German, French, Italian, Dutch, Portuguese, Japanese, Simplified Chinese, and Traditional Chinese)
On-screen Display (OSD) user controls
Brightness, Contrast, Color Control, Input Control, Image Control, Power Control, Menu Control, Management, Language, Information, and Exit
Signal interface/performance
Specification
Native resolution
Preset graphic modes (non-interlaced)
640 x 480 at 60 Hz
720 x 400 at 70 Hz
800 x 600 at 60 Hz
1024 x 768 at 60 Hz
1280 x 720 at 60 Hz
1280 x 800 at 60 Hz
1280 x 1024 at 60 Hz
1440 x 900 at 60 Hz
1600 x 900 at 60 Hz
1680 x 1050 at 60 Hz
Pixel clock
170 MHz
Vertical frequency
50 - 60 Hz
Horizontal frequency
30 - 80 kHz
Video/other inputs
Specification
Plug and play
Yes
Input connectors
(1) VGA
(1) DVI (HDCP support)
Video cables included
(1) VGA cable 1.5 m (4.9 ft)
Ergonomics
Specification
Color
Black
Detachable stand
Yes, ships detached
Tilt range
-5° to + 15° vertical
VESA mounting
Yes, 75 mm
Security lock-ready
Yes
Not available on head only model.
Power
Specification
Power supply
Internal
Input power
100 - 240 VAC 50/60 Hz
Maximum power
20 W
Typical power
18 W
Sleep power
0.5 W
Power cable length
1.9 m (6.23 ft)
What's in the box?
Specification
Monitor and accessories
AC power cord, 1.9 m (6.23 ft)
VGA cable, 1.5 m (4.92 ft)
Documentation
CD (includes user guide, warranty, and drivers)
Physical specifications
Specification
Unpacked with stand
Packaged
Unpacked without stand (head only)
Unpacked with stand
2.60 kg (5.73 lb)
Packaged
3.64 kg (8.02 lb)
Head only
2.46 kg (5.42 lb)
Environmental
Specification
Temperature
Operating
5° to 35° C (41° to 95° F)
Non-operating
-20° to 60° C (-4° to 140° F)
Humidity
Operating
20% to 80% non-condensing
Non-operating
5% to 95%
Altitude
Operating
0 to 5,000 m (0 to 16,400 ft)
Non-operating
0 to 12,192 m (0 to 40,000 ft)
Arsenic-free display glass
Yes
White LED backlights
Yes
Mercury-free display backlighting
Yes
Eco-label certifications & declarations
CB
TUV low blue light
CCC
CEL
CECP
SEPA
WEEE
