HP PCs - Improving Device Performance with Windows Security and Fresh Start (Windows 10)
This document is for HP and Compaq computers with Windows 10.
Windows Security helps protect your computer against pop-ups, slow performance, and security threats caused by viruses and spyware. This document focuses on the performance and health of your PC. Use this document to check PC performance and health or perform a clean reinstallation and update of Windows 10 through Windows Security.
Windows Security steps and screens vary depending on your version of Windows 10.
For business computers, security settings might be managed at the IT level and might not be available to configure or run a Fresh start in Windows. To confirm, contact your company's IT department or your local IT service.
