HP PageWide Pro 750, MFP 772, 777 - Fax memory
NAND memory protects the product against data loss when a power failure occurs. NAND can maintain data for years without power applied.
The product stores about 10MB of memory. This is approximately 500 black-and-white A4 pages at standard resolution, based on standard ITU-T Test Image No. 1. More complicated pages or higher resolution takes longer and uses more memory.
Reprint a fax
  1. On the control panel, touch the Fax icon.
  2. Touch Reprint.
  3. Touch the entry for the fax that you want to reprint.
Delete faxes from memory
Use this procedure if you are concerned that someone else has access to your product and might try to reprint faxes from the memory.
In addition to clearing the reprint memory, this procedure clears any fax that is currently being sent, unsent faxes that are pending redial, faxes that are scheduled to be sent at a future time, and faxes that are not printed or forwarded.
  1. Open the control panel dashboard (swipe the dashboard tab at the top of any screen downward, or touch the strip at the top of the home screen).
  2. On the control panel dashboard, touch (Setup).
  3. Touch Fax Setup, and then touch Tools.
  4. Touch Clear Fax Logs/Memory.
