HP PageWide Pro 750, MFP 772, 777 - Send a fax using printer memory
To turn on the Scan and Fax method
  1. Open the control panel dashboard (swipe the dashboard tab at the top of any screen downward, or touch the strip at the top of the home screen).
  2. On the control panel dashboard, touch (Setup).
  3. Touch Fax Setup, and then touch Preferences.
  4. Touch Scan and Fax Method, and turn it on.
To send a fax using printer memory
  1. Make sure that the Scan and Fax method is turned on.
  2. Load your original print-side down on the scanner glass or print-side up in the automatic document feeder.
    For more information, see Load the scanner or Load the document feeder.
  3. On the control panel, touch the Fax icon.
  4. In the display, touch the Send Now icon, and follow the onscreen instructions.
  5. Use the keypad to enter the fax number or select it from the phone book.
  6. For a color fax, touch Settings, and then Color/Black and Send Fax as Color.
  7. Touch Send.
    The printer scans the originals into memory and sends the fax when the receiving fax machine is available.
