Load your original print-side down on the scanner glass or print-side up in the automatic document feeder.For more information, see Load the scanner or Load the document feeder.
On the control panel, touch the Fax icon.
Do one of the following:
To send the fax now, touch the Send Now icon, and follow the onscreen instructions.
To send the fax later, touch the Send Later icon, follow the onscreen instructions, and set the fax time.
Use the keypad to enter the fax number.
For a color fax, touch Settings, and then Color/Black and Send Fax as Color.
Touch Send.
- ${title}
- ${title}
- ${title}
- ${title}
HP PageWide Pro 750, MFP 772, 777 - Send a fax from the control panel
Additional support options
- ${title}
- ${title}
- ${title}
Country/Region:
Vietnam
- ${title}
hp-hero-support-search
- ${title}
