HP PageWide Pro 750, MFP 772, 777 - Scan to a USB drive
Scan to a USB drive
  1. Load your original print-side down on the scanner glass or print-side up in the automatic document feeder.
    For more information, see Load the scanner or Load the document feeder.
  2. Insert a USB device into the USB port on the front or back of the product.
  3. On the control panel, touch the Scan icon. Then, touch the USB icon.
  4. Touch Settings or (Setup) to select color, size, and resolution options from the Settings menu.
  5. Touch Hide Settings or (Back) to return to the Scan to USB menu, and select a file type from the Save As list.
  6. Touch Filename, and use the keypad to assign a name to the scanned file. Touch Done.
  7. Touch Save.
Country: Flag Vietnam
