HP PageWide Pro 750, MFP 772, 777 - To print from a computer (OS X)
These instructions apply to printing on various media including the following.
  • Plain paper
  • Letterhead or preprinted forms
  • Envelopes
  • Photos
  • Brochures
  • Labels
  1. Load the supported media in the correct tray.
    For more information, see Load media.
  2. On the File menu in the software program, click Print.
  3. Make sure your printer is selected.
  4. In the Presets menu, select a printing preset if needed.
  5. If the product contains a stapler/stacker, then do the following:
    1. From the Copy & Pages pop-up menu, select Finishing.
    2. From the Staple pop-up menu, select one of the following:
      • None: No staples.
      • One Staple Left: The staple is in the left corner of the top edge of the paper.
      • One Staple Right: The staple is in the right corner of the top edge of the paper.
    3. Output Bin - Automatically select: The printer outputs jobs to the upper bin for stapling. All other jobs are routed to the lower bin.
    4. Output Bin - Upper Bin: The printer outputs jobs that support stapling to the upper bin; they do not need to be stapled. All other jobs are routed to the lower bin.
  6. On the Paper/Quality tab, click the pop-up menu next to the media type.
    Set the correct print options for your media (plain paper, letterhead, preprinted, prepunched, envelope, photo paper, label, and so forth). Print options can include size, type, tray, print resolution, and automatic adjustments.
    If you do not see options on the Print dialog box, click Show Details.
  7. Click Print.
    After printing, remove any special media, such as envelopes or photo paper, from the product.
