HP LaserJet Enterprise MFP M631, M632, M633 - Load Tray 2 and the 550-sheet trays
The following information describes how to load paper into Tray 2 and the optional 550-sheet trays. These trays hold up to 550 sheets of 75 g/m2 (20 lb) paper.
The procedure to load paper for the 550-sheet trays is the same as for Tray 2. Only Tray 2 is shown here.
Figure : Tray 1 on the printer
  1. Open the tray.
    Do not open this tray while it is in use.
    Figure : Open the tray
  2. Adjust the paper-length and paper-width guides by squeezing the blue adjustment latches and sliding the guides to the size of the paper being used.
    Figure : Adjust the guides
  3. Load paper into the tray. Check the paper to verify the guides touch the stack, but do not bend it. For information about how to orient the paper, see Tray 2 and the 550-sheet trays paper orientation.
    To prevent jams, do not overfill the tray. Be sure that the top of the stack is below the tray full indicator.
    If the tray is not adjusted correctly, an error message might appear during printing or the paper might jam.
    Figure : Load paper
  4. Close the tray.
    Figure : Close the tray
  5. The tray configuration message displays on the printer control panel.
  6. Touch the OK button to accept the detected type and size, or touch the Modify button to choose a different paper size or type.
    For custom-size paper, specify the X and Y dimensions for the paper when the prompt displays on the printer control panel.
    Figure : X and Y dimensions
  7. Select the correct type and size, and then touch the OK button.
Paper type
Image orientation
Duplex mode
Paper size
How to load paper
Letterhead or preprinted
Portrait
1-sided printing
Letter, Legal, Executive, Statement, Oficio (8.5 x 13), 4 x 6, 5 x 7, 5 x 8, A4, A5, A6, RA4, B5 (JIS), B6 (JIS), L (90 x 130 mm), 10 x 15 cm, Oficio (216 x 340), 16K 195 x 270 mm, 16K 184 x 260 mm, 16K 197 x 273 mm, Double Japan Postcard Rotated (Double Postcard (JIS))
Face-up
Top edge at the left side of the tray
Landscape
1-sided printing
Face-up
Top edge toward the back of the tray
Automatic 2-sided printing or with Alternative Letterhead Mode enabled
Letter, Legal, Executive, Oficio (8.5 x 13), A4, A5, RA4, Oficio (216 x 340), 16K 195 x 270 mm, 16K 184 x 260 mm, 16K 197 x 273 mm
Face-down
Prepunched
Portrait or landscape
1-sided printing
Face-up
Holes toward the back of the tray
Face-down
Holes toward the front of the tray
Use alternative letterhead mode
Use the Alternative Letterhead Mode feature to load letterhead or preprinted paper into the tray the same way for all jobs, whether printing to one side of the sheet of paper or to both sides. When using this mode, load paper as for automatic duplex printing.
To use the feature, enable it by using the printer control-panel menus.
Enable Alternative Letterhead Mode by using the printer control-panel menus
  1. From the Home screen on the printer control panel, open the Settings menu.
  2. Open the following menus:
    • Copy/Print
    • Manage Trays
    • Alternative Letterhead Mode
  3. Select On.
Country: Flag Vietnam
