    We are upgrading our website
HP LaserJet Enterprise MFP M631, M632, M633 - Load paper to Tray 1 (multipurpose tray)
The following information describes how to load paper in Tray 1.
Figure : Tray 1 on the printer
To avoid jams, never add or remove paper from Tray 1 during printing.
  1. Open Tray 1.
    Figure : Open Tray 1
  2. Pull out the tray extension to support the paper.
    Figure : Pull out the tray extension
  3. Use the blue adjustment latch to spread the paper guides to the correct size, and then load paper in the tray. For information about how to orient the paper, see Tray 1 paper orientation.
    Make sure that the paper fits under the fill line on the paper guides.
    The maximum stack height is 10 mm, or approximately 100 sheets of 75 g/m2 paper.
    Figure : Adjust the guides and then load paper
  4. Using the blue adjustment latch, adjust the side guides so that they touch the paper stack, but do not bend it.
Paper type
Image orientation
Duplex mode
Paper size
How to load paper
Letterhead or preprinted
Portrait
1-sided printing
Letter, Legal, Executive, Statement, Oficio (8.5 x 13), 3 x 5, 4 x 6, 5 x 7, 5 x 8, A4, A5, A6, RA4, B5 (JIS), B6 (JIS), L (90 x 130 mm), 10 x 15 cm, Oficio (216 x 340), 16K 195 x 270 mm, 16K 184 x 260 mm, 16K 197 x 273 mm, Japanese Postcard (Postcard (JIS)), Double Japan Postcard Rotated (Double Postcard (JIS))
Face-down
Bottom edge leading into the printer
Automatic 2-sided printing or with Alternative Letterhead Mode enabled
Letter, Legal, Executive, Oficio (8.5 x 13), A4, A5, RA4, B5 (JIS), Oficio (216 x 340), 16K 195 x 270 mm, 16K 184 x 260 mm, 16K 197 x 273 mm
Face-up
Top edge leading into the printer
Landscape
1-sided printing
Face-down
Top edge toward the front of the printer
Face-up
Prepunched
Portrait and landscape
1-sided printing
Holes toward the front of the printer
Use alternative letterhead mode
Use the Alternative Letterhead Mode feature to load letterhead or preprinted paper into the tray the same way for all jobs, whether printing to one side of the sheet of paper or to both sides. When using this mode, load paper as for automatic duplex printing.
To use the feature, enable it by using the printer control-panel menus.
Enable Alternative Letterhead Mode by using the printer control-panel menus
  1. From the Home screen on the printer control panel, open the Settings menu.
  2. Open the following menus:
    • Copy/Print
    • Manage Trays
    • Alternative Letterhead Mode
  3. Select On.
Country: Flag Vietnam
