Document ID: c05478185
Version: 1
Advisory: HP Pro X2 612 G2 - Fingerprint Reader Is Not Detected
Release date : 18-Apr-2017
Last updated : 19-Apr-2017
DESCRIPTION
The fingerprint reader is not detected by the computer. The fingerprint reader will not work, and it is not possible to setup the fingerprint reader for the computer.
SCOPE
Systems:
  • HP Pro x2 612 G2
RESOLUTION
To resolve this issue, download and install the following SoftPaq:
SoftPaq Description
Release Notes
Download SoftPaq
Synaptics VFS7552 WBF Touch Fingerprint Sensor Driver
Version: 5.2.5005.26
Revision: A
NOTE: A more recent version of this software may be available. Check for newer versions at http://www.hp.com/drivers.
Hardware platforms affected : HP Pro x2 612 G2
Support Communication Cross Reference ID : IA05478185
