HP N320c 31.5-inch Curved Monitor - Specifications
Panel
Specification
Type
VA with LED backlight
80.01 cm (31.5 in)
Panel active area (W x H)
698.5 x 392.94 mm (27.5 x 15.47 in)
Aspect ratio
16:9
Viewing angle (typical CR>10)
178° horizontal
178° vertical
Brightness (typical)
300 cd/m2
Contrast ratio (typical)
3000:1 static
Dynamic contrast ratio (typical)
6,000,000:1 dynamic (DCR)
Dynamic contrast ratio during video playback only, depending on series of frames or time duration.
Response times (typical)
5 ms Gray to gray (with OD)
Pixel pitch
0.12125 (H) x 0.36375 (W) mm
Pixels Per Inch (PPI)
70
Default color temperature
Neutral 6500 K
Backlight lamp life
30,000 hours minimum (to half brightness)
Color gamut (typical)
72%
Color support
Displays up to 16.7 million colors (with the use of FRC technology)
Anti-glare panel
Yes
Actual performance varies.
User controls
Specification
Monitor control buttons or switches
Menu, Up, Down, Minus ("-"), Plus ("+"), Power On/off, and OK
Color Control, Next Input, and Information
User Programmable Modes
Yes, 8
Languages
10 (English, Spanish, German, French, Italian, Dutch, Portuguese, Japanese, Simplified Chinese, and Traditional Chinese)
On-screen Display (OSD) user controls
Brightness, Contrast, Color Control, Input Control, Image Control, Power Control, Menu Control, Management, Language, Information
HP Display Assistant
Signal interface/performance
Specification
Native resolution
1920 x 1080 at 60 Hz
The video card of the connected PC must be capable of supporting 1920 x1080 at 60 Hz and include (1) VGA output and (1) DVI-D to drive the monitor at the preferred mode.
Maximum resolution
Recommended resolution
Preset graphic modes/supported resolutions
640 x 480 at 60Hz
800 x 600 at 60 Hz
1024 x 768 at 60 Hz
1280 x 720 at 60 Hz
1280 x 800 at 60 Hz
1280 x 1024 at 60 Hz
1440 x 900 at 60 Hz
1600 x 900 at 60 Hz
1680 x 1050 at 60 Hz
Maximum pixel clock speed
170 MHz
Vertical scan range
50 - 70 Hz
Horizontal scan range
24 - 80 kHz
Video/other inputs
Specification
Plug and play
Yes
Input connectors
(1) VGA
(1) USB (charging)
(1) DVI-D
HDCP support on DVI.
Ergonomics
Specification
Exterior color of monitor bezel and stand
Bezel
White
Stand
Silver
Tilt
-5 to +15°
Security lock ready
Yes
VESA mounting
Yes, 100 mm
Power
Specification
Power supply
Internal
Input power
100 - 240 VAC 50/60 Hz
Maximum power
65 W
Typical power
50 W
Power saving
0.5 W
Power cable length
1.9 m (6.23 ft)
Physical specifications
Specification
Dimensions (W × D × H)
Unpacked with stand
72.14 x 20.83 x 49.53 cm (28.40 x 8.20 x 19.50 in)
Packed
86.0 x 26.39 x 63.40 cm (33.86 x 10.39 x 24.96 in)
Unpacked without stand
72.14 x 9.40 x 43.18 cm (28.4 x 3.7 x 17.0 in)
Unpacked with stand
7.9 kg (17.42 lb)
Packed
11.24 kg (24.78 lb)
Head only
7.15 kg (15.76 lb)
Environmental
Specification
Temperature
Operating
5° to 35° C (41° to 95° F)
Non-operating
-20° to 60° C (-4° to 140° F)
Humidity
Operating
20% to 80% non-condensing
Non-operating
5% to 95%
Altitude
Operating
0 to 5,000 m (0 to 16,400 ft)
Non-operating
0 to 12,192 m (0 to 40,000 ft)
Arsenic-free display glass
Yes
Mercury-free display backlighting
Yes
Eco-label certifications & declarations
China Energy Label (NEW Grade 2)
Agency approvals and certifications
CB, CE, CCC, China CEL, Taiwan BSMI, ISC, PSB
What's in the box?
Specification
Accessories
AC power cord, 1.9 m (6.23 ft)
VGA cable, 1.5 m (4.92 ft)
Set-up poster
Hard copy warranty booklet (country specific)
CD
CD (includes User guide, warranty, and drivers)
