HP N270c 27-inch Curved Monitor - Specifications
Panel
Specification
Type
VA
68.58 cm (27 in) widescreen
Panel active area (W x H)
599.161 x 336.321 mm (23.589 x 13.241 in)
Aspect ratio
16:9
Viewing angle (typical CR>10)
178° horizontal
178° vertical
Brightness (typical)
300 cd/m2
Contrast ratio (typical)
3000:1 static
Dynamic contrast ratio (typical)
10,000,000:1 dynamic (DCR)
Dynamic contrast ratio during video playback only, depending on series of frames or time duration.
Response times (typical)
Panel native 21 ms
OD GTG function supports up to 5 ms
Pixel pitch
0.3114 mm (H) x 0.3114 mm (W)
Pixels Per Inch (PPI)
81.6
Default color temperature
Standard 6500 K
Backlight lamp life
30,000 hours minimum (to half brightness)
Color gamut (typical)
sRGB 99% or above
Color support
Displays up to 16.7 million colors (with the use of FRC technology)
Low haze panel
Yes
Actual performance varies.
User controls
Specification
Buttons or switches
Menu
Plus ("+")/Next Input
Minus ("-")/Viewing Modes
OK/Information
Power
User Programmable Modes
Yes, 10
Languages
10 (English, Spanish, German, French, Italian, Dutch, Portuguese, Japanese, Simplified Chinese, and Traditional Chinese)
On-screen Display (OSD) user controls
Brightness, Contrast, Color Control, Input Control, Image Control, Power control, Menu Control, Management, Language, Information, and EXIT
HP Display Assistant
Signal interface/performance
Specification
Native resolution
1920 x 1080 at 60 Hz
Maximum resolution
Recommended resolution
Preset graphic modes/supported resolutions
640 x 480 at 60Hz
720 x 480 at 60 Hz
800 x 600 at 60 Hz
1024 x 768 at 60 Hz
1280 x 720 at 60 Hz
1280 x 1024 at 60 Hz
1440 x 900 at 60 Hz
1600 x 900 at 60 Hz
1680 x 1050 at 60Hz
1920 x 1080 at 60Hz
Maximum pixel clock speed
180 MHz
Vertical scan range
50 - 76 Hz
Horizontal scan range
30 - 86 Khz
Low haze
Yes
Video/other inputs
Specification
Plug and play
Yes
Input connectors
(1) VGA, 1.8 m (5.91 ft)
(1) HDMI, 1.8 m (5.91 ft)
(1) DisplayPort 1.2, 1.8 m (5.91 ft)
HDCP support on HDMI and DP.
Audio
(1) Audio output
Power
Specification
Power supply
Module
Input power
100 - 240 VAC 50/60 Hz
Maximum power
41.5 W
Typical power
33.5 W
Power saving
0.5 W
Power cable length
1.9 m (6.23 ft)
Physical specifications
Specification
Dimensions (W × D × H)
Unpacked with stand
61.34 x 16.89 x 43.84 cm (24.15 x 6.65 x 17.26 in)
Packed
73.20 x 22.50 x 52.60 cm (28.82 x 8.86 x 20.71 in)
Unpacked without stand
61.34 x 6.99 x 36.37 cm (24.15 x 2.75 x 14.32 in)
Unpacked with stand
5.4 kg (11.91 lb)
Head only
5.0 kg (11.02 lb)
Ergonomic features
Specification
Exterior color of monitor bezel and stand
Black Onyx
Detachable base
Yes
Tilt range
-5° to +25°
VESA mounting
Yes, 100 mm
Security lock ready
Yes
Environmental
Specification
Temperature
Operating
5° to 35° C (41° to 95° F)
Non-operating
-20° to 60° C (-4° to 140° F)
Humidity
Operating
20% to 80% non-condensing
Non-operating
5% to 95%
Altitude
Operating
0 to 5,000 m (0 to 16,400 ft)
Non-operating
0 to 12,192 m (0 to 40,000 ft)
Arsenic-free display glass
Yes
Low halogen
Yes
External power supplies, power cords, cables, and peripherals are not Low halogen. Service parts obtained after purchase might not be Low halogen.
Mercury-free display backlighting
Yes
Eco-label certifications & declarations
China Energy Label (NEW Grade 2)
Agency approvals and certifications
WW application
CE,CB,MSIP/ICES/CCC/CEL/EPA/ISC/VCCI/FCC/Taiwan: BSMI/ISO 9241-307/Mexico CoC/cTUVus/EAC/RCM/Ukraine/Morocco
What's in the box?
Specification
Accessories
AC power cord, 1.9 m (6.23 ft)
VGA cable, 1.8 m (5.91 ft)
CD
CD (includes User guide, warranty, and drivers)
